- All ebook Ajax
All ebook Ajax
Ajax and REST Recipes: A Problem-Solution Approach (Paperback)
AUTHOR : by Christian Gross (Author)
PUBLISHER : Apress publisher
ISBN : 1590597346
EDITION : 1st
PUB DATE : December 18, 2006
LANGUAGE : English
RLS DATE : 05/06/2007
MAKER : BBL
SUPPLIER : BBL
PACKAGER : BBL
FORMAT : PDF
SIZE : 07 x 2.88 MB
[ R e l e a s e N o t e s ]
Ajax and REST Recipes: A Problem-Solution Approach will serve all of
your Ajax needs, by providing adaptable solutions for common tasks
you'll want to implement on web sites using the next generation of Ajax
and REST techniques. As a JavaScript developer, your time is precious,
so you'll want to solve problems that present themselves in your work as
quickly as possible. You can pick up the code provided in this book,
adapt it, or plug it straight into your own applications. The book
mainly focuses on illustrating and explaining how to build applications
that use JavaScript, Ajax, and REST Web Services, along with some user
interface issues. Specifically, the following topics are covered:
implementing JavaScript unit tests; explaining the intent of Dynamic
Languages, Web Services and SOA; defining and implementing contracts
using REST; understanding why JavaScript Functions have state;
implementing JavaScript "Generics", which are a mixture between real
Generics and a replacement algorithm; using code blocks; using functions
to make decisions; understanding the difference of JavaScript code that
behaves like a value type or a reference type; implementing proxies,
delegates, mixins, and overloaded functions; implementing a complete
Ajax and Web Service architecture; defining a Web Service using REST;
handling large or slow or real-time data sets; implementing shopping
cart type architectures; and solving the back button problem using Ajax.
Having read this book you will learn how to modularize your web
application by decoupling the client from the server. The decoupling
allows a client developer to focus on writing the best JavaScript and
Ajax code, and a server developer to write the best business and data
objects.
Download
http://depositfiles.com/files/835018
http://rapidshare.com/files/29863870/1590597346.zip
Có bro nào có E-book cho ajax viết cho asp.net không cho mình xin với!nếu sách bằng tiếng việt thì càng tốt!
Search trên google đi bạn
Mình thấy có nhiều lắm.
amazon, code, ebook, javascript, server, web, ajax, implementing, rest, book, developer, type, functions, applications, data, service, generics, decoupling, client, understanding, defining, explaining, services, problem-solution, recipes, date, publisher, author, approach, real, mixture, replacement, algorithm, reference, behaves, make, decisions, difference, blocks, christian, unit, tests, intent, apress, covered, topics, isbn, dynamic, languages, proxies 4.5 5 5272
