Trang 1 của 9 1 2 3 4 ... CuốiCuối
Kết quả 1 đến 15 của 130
    anhnn2010's Avatar
    anhnn2010 Đang Ngoại tuyến
    Jan 2011
    ESET NOD32 Antivirus/Smart Security 8.0.304.0 [21.10.2014]
    Powerful Fast Antivirus
    Antivirus | Antispyware | Gamer Mode | Anti-Phishing
    Cloud-powered Scanning | Social Media Scanner
    Stay Safe Online: Stay a Safe Distance from Internet Threats
    Employing the time-tested NOD32 technology, the solution eliminates all types of Internet threats. The cloud-powered scanning delivers a higher level of protection, speeding up scans and ensuring that your system runs at its best.
    • Antivirus and Antispyware
    • Cloud-powered Scanning
    • Anti-Phishing
    • Scan While Downloading Files
    • Removable Media Control
    • Host-based Intrusion Prevention System (HIPS)
    • Social Media Scanner
    Top Speed Performance: Enjoy the Full Power of Your Computer
    Leaving more power to programs you use daily, ESET lets you play and work without slowdowns. Stay unplugged and online longer with battery-saving mode and enjoy gaming without distracting pop-ups.
    • Small System Footprint
    • Gamer Mode
    • Portable Computer Support
    Solution That Fits You: Install and Forget or Tweak Away
    Delivering top protection right from the start, the solution lets you address security issues directly from the main screen. Quickly find the settings you need and fine-tune your security profile with more than 150 options.
    • One-click Solution
    • Settings for Advanced Users
    • After-scan Actions
    ESET Smart Security
    All-in-One Internet Security
    Antivirus | Antispyware | Antispam | Anti-Theft | Firewall
    Parental Control | Anti-Phishing | Social Media Scanner
    Anti-Theft: Locate and Retrieve Your Missing Laptop
    Locate your missing laptop on the map and watch the activity taking place on the system. With ESET Anti-Theft's easy setup, your computer-stored datawill be protected at a higher level.
    • Location Tracking
    • Laptop Activity Watch
    • Anti-Theft Diagnostics
    • One-way Messaging
    Identity Theft Protection: Keep Your Private Data Safe from Identity Theft
    Stop hackers from misusing your passwords and bank account details. Stay invisible to other users in public Wi-Fi networks and protect your data from being copied to unauthorized USB storage devices.
    • Personal Firewall
    • Antispam
    • Anti-Phishing
    • Out-of-Home Network
    • Anti-Phishing
    • Gamer Mode
    Parental Control: Keep Kids Safe on the Internet
    Show your kids only the good side of the Internet and prevent them being exposed to potentially offensive content. Block more than 20 website categories and add additional websites to the blacklist if required.
    • Parental Control
    • Password Protection
    System requirements
    • Microsoft Windows 8, 8.1
    • Microsoft Windows 7
    • Microsoft Windows Vista
    • Microsoft Windows XP
    • Microsoft Windows Home Server 2003, 2011*
    * Anti-Theft does not run on Microsoft Windows Home Servers
    So sánh ESET NOD32 Antivirus và Smart Security
    Nội dung ẩn:
    Homepage
    Changelog
    Download | NOD32 Antivirus x86
    Download | NOD32 Antivirus x64
    Download | Smart Security x86
    Download | Smart Security x64
    TNod User & Password Finder | 1.4.2.3 (Inserts license into ESET.) | Hướng dẫn tại đây
    MiNodLogin | Mirror v4.0.2.66 (Inserts license into ESET. Requires Java Runtime Environment.)
    box, mara-fix | Mirror v1.8
    * Password: softvnn.com
    + Hướng dẫn sử dụng TNOD để chèn key tự động cho ESET
    Important: Disable ESET before trying to download any fixes listed here. Before installing, we recommend uninstalling your current protection (including older versions of ESET software), to ensure a smooth transition. You can export all your settings before you uninstall ESET.
    Lần sửa cuối bởi Endless4U, ngày 23-10-2014 lúc 03:12 PM. Lý do: fix link!
    re: ESET NOD32 Antivirus/Smart Security 6.0.314.0 [25.03.2013]
    Quá nhiều người sai lầm khi ko dùng AV này
    Bản 6 này chạy mượt hơn bản 5
  3. The Following 6 Users Say Thank You to Lovesvnn For This Useful Post:
    angelk's Avatar
    angelk Đang Ngoại tuyến Thành viên Softvnn
    lúc trước xài thằng này nhưng giờ chuyển qua Avast rồi..hôm nào cài lại máy đổi lại thử xem :lookdown:
  5. The Following 2 Users Say Thank You to angelk For This Useful Post:
    13liker Đang Ngoại tuyến Thành viên mới
    TNOD dùng sao hả bác ^^
    nhochocdoi's Avatar
    nhochocdoi Đang Ngoại tuyến Thành viên mới
    Sep 2011
    ad ơi, k crack đc
    kenzicoca567 Đang Ngoại tuyến Thành viên mới
    Aug 2010
    19F Lê Trực Phường 7 .Quận Bình Thạnh
    cái chức năng anti theft của eset là gì vậy bác
    congtoan.net Đang Ngoại tuyến Thành viên mới
    Trích dẫn Gửi bởi kenzicoca567 Xem bài viết
    Chức năng này sử dụng khi máy tính bạn bị mất đấy, hiển thị bản đồ, máy tự chụp hình lại hình ảnh người sử dụng...
    huyen_bn Đang Ngoại tuyến Thành viên mới
    Trích dẫn Gửi bởi congtoan.net Xem bài viết
    Laptop không có Webcam thì "chụp" ảnh kẻ trộm bằng niềm tin hả bạn ?
    Tunghuynhag Đang Ngoại tuyến Thành viên mới
    Jan 2013
    Hướng dẫn cách crack eset 6 dùm cái bạn ơi.
  12. #10
    Link down ở đây
    http://softvnn.googlecode.com/files/TNod-v1.4.2.1-final-setup.rar
    fix lỗi không tìm thấy key: http://www.mirrorcreator.com/files/09NH2KXD/
    1. Giải nén TNOD Portable hay cài vào 1 nơi nào đó ví dụ C:\Program Files\ESET, cài xong khoan chạy nó
    2. Cài ESET
    3. Mở ESET, Bấm F5, vào mục Computer > Antivirus and antispyware > Exclusions > Bấm nút Add rồi chọn thư mục chứa TNOD
    giả sử như bước 1, ta chọn C:\Program Files\ESET
    4. Mở ESET, Bấm F5, vào mục Web and mail > Web access protection > URL address management > Bấm nút Add thêm vào các địa chỉ sau:
    http://clavesnod32serial.blogspot.com*
    http://keynod-alexros.blogspot.ru*
    http://nod32sky1.blogspot.com*
    http://nuevaslicenciasnod32.blogspot.com*
    http://premium-downloadz.blogspot.com*
    http://shorturls.tukero.org*
    http://tnoduse2.blogspot.com*
    http://www.blogger.com*
    Để thêm nhanh, ta dùng notepad lưu danh sách trên thành 1 file txt, bấm nút mũi tên kế nút Add > From File rồi chọn file txt này
    5. Chạy TNOD để nó tự điền key (có thể chỉnh TNOD khởi động cùng Win thì không cần ta chạy), lưu ý nếu ESET đang update thì TNOD sẽ không chèn key được, đợi update xong thì chạy
    Lưu ý:
    - Nếu bạn cài ESET trước và để ESET phát hiện TNOD trước khi bạn exclusions, có thể sẽ không thể exclusions được nữa
    Lúc này bạn cứ để ESET xóa TNOD, lúc cần chạy TNOD, bạn disable ESET, vào Quarantine khôi phục lại file chạy TNOD
    Chạy TNOD vừa khôi phục để chèn key, chèn xong ESET sẽ xóa tiếp, sau này muốn chạy TNOD thì lặp lại như trên.
    - Bạn có thể vào trang ESET Nod32 Username And Password để key
    Video hướng dẫn cách cài đặt ESET, TNOD và một số tùy chỉnh
    Lần sửa cuối bởi Lovesvnn, ngày 28-11-2013 lúc 12:51 PM.
  13. #11
    Jan 2013
    Cám ơn bạn nhiều! Mình đang sử dụng eset 5 tính nâng lên 6 xem có gì mới không.
  14. #12
    xetuira Đang Ngoại tuyến Thành viên mới
    cho hỏi, từ bản 5 lên bản 6, có cần phải unistall bản 5 không, hay là cài đè lên luôn vậy?
  15. #13
    Agamx Đang Ngoại tuyến Thành viên mới
    Feb 2013
    Trích dẫn Gửi bởi xetuira Xem bài viết
    Cài đè vẫn được bạn nhé!
  16. The Following User Says Thank You to Agamx For This Useful Post:
  17. #14
    hungsao's Avatar
    hungsao Đang Ngoại tuyến Thành viên mới
    Jun 2006
    Trích dẫn Gửi bởi Lovesvnn Xem bài viết
    Bạn nên xài TNOD down ở đây
    1. Bấm F5, đưa vào exclusion như 2 hình dưới
    2. giải nén TNOD vào C:\Program Files\ESET (nếu giải nén chỗ khác thì bị ESET xóa ngay)
    cài đặt TNOD, lần đầu chạy, TNOD thường không tìm được key
    3. bạn vào ESET Nod32 Username And Password lấy 1 key để đăng kí
    sau này có thể xài chùa vĩnh viễn luôn mà ko cần làm gì nữa
    Bác copy các list of addresses vào thẻ QUOTE thì tốt quá
    khi co don em nho ai....
  18. The Following 2 Users Say Thank You to hungsao For This Useful Post:
  19. #15
  20. The Following 7 Users Say Thank You to Lovesvnn For This Useful Post:
ảnh, bạn, bất, biểu, cài, cách, của, cho, giải, hình, internet, kết, không, khi, làm, lên, lại, máy, mọi, một, nay, nào, trên, vào, với, x64, đưa, được, eset, security, antivirus, solution, system, media, stay, nod32, protection, safe, control, windows, microsoft, settings, download, scanner, social, scanning, cloud-powered, anti-phishing, mode, enjoy 4.5 5 37773
