Kết quả 1 đến 15 của 23
    Endless4U's Avatar
    Endless4U Đang Ngoại tuyến Lãng Tử Gió
    Oct 2010
    Đâu?
    Adobe Acrobat XI Pro 11.0.0 [17.10.2012]
    Adobe ® Acrobat ® Pro XI
    Adobe ® Acrobat ® Pro XI - it's not just convert your PDF. It contains many smart features that provide more opportunities for interaction. Easily, quickly and professionally. Combining a wide range of content including documents, spreadsheets, email, images, video, 3D-graphics and maps in one concise and structured portfolio PDF. Joint work in reviewing the documents to which granted total access. Creating interactive forms and rapid collection of data. Protect and control sensitive information. Advanced features Acrobat software for users of Adobe Reader ®.
    Additional Information
    Evaluate the effectiveness of technology Adobe ® Acrobat ® Dynamic PDF for creating and sharing PDF files, a new generation. Collaborate with colleagues, customers and partners through the use of sessions reviewing electronic documents, fillable PDF forms and services Acrobat.com. Combine multiple file types into a polished, organized PDF Portfolio of professional quality. Install passwords and permissions to protect documents. Increase the attractiveness of documents using a multifunctional content.
    Main functions:
    • Convert and Scan to PDF. No matter what type of content is converted into a format or scanned PDF - «paper" documents, emails, photos, spreadsheets, websites, videos, compatible with Adobe ® Flash ® Player, or other types of content - all the work is easily performed using the software software Adobe Acrobat ® X. Create and provide shared access to files PDF, which can be viewed on mobile devices and smartphones.
    • Export and edit files PDF. Easily edit PDF documents and export them to Word and Excel. You no longer need to enter each time data from the keyboard, you can reuse the prepared content. Use Acrobat X to reduce errors, improve productivity and reduce development time of projects.
    • Combine files from multiple applications. You no longer need to send a lot of letters with numerous attachments. Create professional files of PDF, which are easy to send, open and view.
    • Improved efficiency and consistency of work. Use innovative features to improve productivity to simplify complex processes, training and demonstration of high-quality content and achieve good results.
    • Streamlined document reviews online. Effectively collect feedback from colleagues and customers and reduces the time required for approval of projects. Use the tools share online review and commenting of PDF documents to facilitate collaboration on the project.
    • Collect data with fillable forms PDF. Easily create, distribute and track interactive forms convenient PDF, similar to a "paper" - you do not need the help of the IT department.
    • Protect PDF files and documents. Easy-to-use security features can protect confidential information. Passwords, digital signatures, and corrections functions allow you to implement secure electronic processes.
    • Standards Compliance and PDF support for accessibility features. Ensure compliance with corporate, regional and state standards, and add accessibility features for persons with disabilities.
    • Reading files PDF, search for them and file sharing. With the free software Adobe ® Reader ® provides all users the ability to view and print PDF, and also perform search on them. Work on PDF files with colleagues and customers - even if you use different file formats, platforms, browsers and devices.
    System requirements:
    • Processor with a clock speed of 1.3 GHz or higher
    • Microsoft ® Windows ® XP with Service Pack 3 (32-bit) or Service Pack 2 (64-bit); Windows Server ® 2003 R2 (32 - and 64-bit); Windows Server 2008 or 2008 R2 (32 - and 64-bit); Windows 7 (32 - and 64-bit); Windows 8 (32 - and 64-bit)
    • 512 MB RAM (1 GB recommended)
    • 1.85 GB of free hard disk space
    • 1024x768 resolution
    • DVD-ROM drive
    • Internet Explorer 7, 8, 9 or 10; Firefox Extended Support Release; Chrome
    • Video hardware acceleration (optional)
    Homepage - Trang chủ
    Changelog
    Note: Ấn vào đây trước khi download
    Download - Tải về [501.16 Mb]
    Thuốc License & Activation
    Thuốc License & Activation Mirror
    Pass Unrar : softvnn.com
    Note : Đọc kĩ hướng dẫn kèm theo!
    Hướng dẫn crack
    1) Turn off the Internet. Acrobat install in trial mode.
    2) Run the program. Take individuals. Agreement. In the next window, click
    to license the software. Run the crack and serial sgeniriruyte for Adobe Acrobat X v10x
    (not close it), enter it in the next window. Click again later.
    3) Further Help> Product Registration> can not connect to the internet>
    autonomous activation> code request form.
    run crack X-FORCE (xf-mccs6.exe) field, enter the serial number of the serial
    keygen first, in the request type request code, then generate the resulting
    activation code (field "Activation") then copy and paste the code in the response. program activation. Now close Acrobat and open the folder C: \ Program Files \ Common Files \ Adobe \ ARM \ 1.0 Locate the files - AdobeARM - Armsvc - AcrobatUpdater and rename them like this AdobeARMold, armsvcold, AcrobatUpdateold If you see a message that the file can not be renamed, look for them in the manager and complete, repeat the procedure. block any attempt to contact the program with the Internet firewall. Run notepad as administrator and fill in the hosts file to C: \ Windows \ system32 \ drivers \ etc \ hosts:
    127.0.0.1 activate.adobe.com
    127.0.0.1 lmlicenses.wip4.adobe.com
    127.0.0.1 lm.licenses.adobe.com
    Lần sửa cuối bởi yuwakuitian, ngày 16-04-2014 lúc 10:47 AM. Lý do: Fix link
    Tài khoản vip dành cho thành viên của SoftVnn.Com
    .                                  TenLua .                                 Megashare
    .            viptenlua.softvnn3@gmail.com / viptenlua.softvnn3         soigia / 12345654321
    engergojita Đang Ngoại tuyến Thành viên mới
    Re: Adobe Acrobat XI Pro 11.0.0 [17.10.2012]
    Đã thử nghiệm thuốc cho Adobe Acrobat Pro XI nhưng rất tiếc không được vì keymaker dành cho Adobe Master Collection CS6 !!!
  3. The Following 3 Users Say Thank You to engergojita For This Useful Post:
    reddevil_1311's Avatar
    reddevil_1311 Đang Ngoại tuyến Thành viên mới
    Dec 2011
    mình đã activate thành công
  5. The Following User Says Thank You to reddevil_1311 For This Useful Post:
    no1rock Đang Ngoại tuyến Thành viên mới
    Oct 2012
    activate thành công nhá
    wolf Đang Ngoại tuyến Thành viên Softvnn
    Có ai dịch giúp cái cách crack ko sao mình ko crack được nhỉ
    Oct 2012
    Trích dẫn Gửi bởi wolf Xem bài viết
    - Ngắt kết nối internet
    - Cài đặt bản trial
    - Chạy Adobe, click vào Get License
    - Nhập serial : 1118-1285-1786-8246-2923-3814
    1118-1184-6774-6560-5266-9723
    - Click Next, Connect Later
    - Tại menu/Help, click PRODUCT REGISTRATION
    - Click Problems internet connection (dòng màu xanh trên cùng bên trái)
    - Click Offline Activation
    - Click Generate Request Code
    - Chạy keygen X-FORCE.exe
    - Paste serial 1118-1285-1786-8246-2923-3814
    hay 1118-1184-6774-6560-5266-9723 vào ô serial
    - Copy RequestCode ở Adobe và paste vào ô Resquest code và click Generate
    - Copy dãy ở ô Response code rồi paste vào Adobe
    - Thêm các dòng sau vào file hosts (C:/windows/system32/drivers/etc):
    - Enjoy!
  9. The Following 10 Users Say Thank You to no1rock For This Useful Post:
    phudai09vn Đang Ngoại tuyến Thành viên mới
    Nov 2011
    key không sử dụng được, up lại đi chủ thớt
    matt Đang Ngoại tuyến Thành viên Softvnn
    Thuốc dùng rất chuẩn
  12. #9
    ponpaul Đang Ngoại tuyến Thành viên mới
    Xin cho mình hỏi, sau 2 lần chặn kết nối với trang chủ Adobe thất bại ( do ESET xóa file host) thì mình đã dùng hết 2 serial trên đây (đều bị revoked cả). Giờ thì mình đã chặn kết nối được rồi, nhưng không còn serial nào khác để activate Adobe Acrobat Pro 11 cả. Ai có thể giúp mình không? CÒn serial nào để activate được thì cho mình xin.
    Cảm ơn rất nhiều
  13. #10
    yuwakuitian's Avatar
    yuwakuitian Đang Ngoại tuyến
    Moderator
    Key đây bạn:
    1118-1877-2633-9049-2980-4507
    1118-1558-1240-4361-4488-9937
    1118-1977-2984-4889-1161-3597
    1118-1341-7242-3094-2854-8996
    1118-1495-2887-0872-5993-1852
    Có thể dùng Keygen của bộ CS5 để tạo key nhé.
  14. The Following 3 Users Say Thank You to yuwakuitian For This Useful Post:
  15. #11
    notjoan Đang Ngoại tuyến Thành viên mới
    Jan 2013
    cảm ơn bạn nha...
  16. #12
    nbhduoc Đang Ngoại tuyến Thành viên mới
    đang kiếm cái này, mà thuốc không biết dùng được ko nữa
  17. #13
    timosi Đang Ngoại tuyến Thành viên Softvnn
    link thuốc đã bị die, cảm phiền úp lại dùm mình được hok? thanks in advance.
  18. #14
    fireUP Đang Ngoại tuyến Thành viên mới
    sửa file host mà không tác dụng, phải dùng firewall chặn nó lại mới được quá hĩ
    Hack,hack nữa,hack mãi mình bị hack....thôi không hack nữa
    Spam,spam nữa,spam mãi mình bị ban nick....tao nick mới...spam,spam nữa,spam mãi.....
  19. #15
    phongpro79's Avatar
    phongpro79 Đang Ngoại tuyến
    Oct 2011
    - Copy cr@ck to install dir
    - Use Firewall
    AA nên dùng Firewall
adobe, lại, pro, được, files, acrobat, documents, activation, content, features, windows, file, 64-bit, software, internet, program, forms, code, easily, protect, work, data, information, crack, customers, create, colleagues, serial, enter, request, time, 127.0.0.1, license, free, search, 2008, devices, support, accessibility, window, type, pack, functions, compliance, server, click, edit, productivity, improve, reduce 4.5 5 11114
