Trang 1 của 6 1 2 3 4 ... CuốiCuối
Kết quả 1 đến 15 của 87
    forvutien Đang Ngoại tuyến
    Moderator
    cFosSpeed 8.02 Build 1972/8.03 Build 2015 Beta [20.01.2013]
    cFosSpeed
    Faster Internet access with Traffic Shaping
    cFosSpeed is a network driver, which attaches itself to existing Internet connections. It then optimizes data transfer by means of Traffic Shaping. Traffic Shaping is a method for optimizing the Internet traffic. It allows maximum speed while ensuring minimal Ping. You can use cFosSpeed with a router and/or a DSL-modem or cable-modem. You can also use cFosSpeed with other types of Internet access, ie. whenever you already have an existing Internet connection. cFosSpeed supports a wide variety of connections, like DSL, cable, ISDN, UMTS, etc.
    Whenever you access the Internet with more than one data stream cFosSpeed can optimize the traffic.
    • Improve your Ping for online games
    • Keep your internet fast during heavy upload/download
    • NEW: Improve mobile Internet
    • Reduce audio/video streaming problems
    • Improve VoIP speech quality
    Highlights
    • cFosSpeed prevents one application (e.g. sending email) from choking all others, like telephone calls, chat, etc.
    • cFosSpeed keeps your ping times low, so you can play online games and download files simultaneously.
    • All important data packets are automatically prioritized over unimportant ones. With the cFosSpeed program and protocol prioritization you can configure your applications ideally and/or add new Programs.
    • Real-time analysis of your data: With the new status window you can easily recognize which data streams you are currently transfering.
    • cFosSpeed runs with DSL, Cable, WLAN, CDMA2000, UMTS, WCDMA, Modem, ISDN, broadband mobile (2G / 3G).
    • Here a detailed explanation of cFosSpeed's Traffic Shaping.
    [Only registered and activated users can see links. ] | 8.03 Beta | 4.63MB
    [Only registered and activated users can see links. ] | 8.02 Final | 4.39MB
    Lần sửa cuối bởi Endless4U, ngày 20-01-2013 lúc 01:44 AM. Lý do: cập nhật!
    Pass: softvnn.com
    Moderator
    Re: cFosSpeed 7.00 Build 1901 Final/ 7.01 Build 1938 Beta [18.04.2012]
    Update cFosSpeed 7.01 Build 1938 Beta
    Pass: softvnn.com
  3. The Following 3 Users Say Thank You to forvutien For This Useful Post:
    anhnn2010's Avatar
    anhnn2010 Đang Ngoại tuyến Thành viên (^.^)
    Jan 2011
    Re: cFosSpeed 7.00 Build 1901 Final/ 7.01 Build 1939 Beta [19.04.2012]
    Cập nhật cFosSpeed 7.01 Build 1939 Beta.
  5. The Following 3 Users Say Thank You to anhnn2010 For This Useful Post:
    anhnn2010's Avatar
    Jan 2011
    Re: cFosSpeed 7.00 Build 1901 Final/ 7.01 Build 1940 Beta [21.04.2012]
    Cập nhật cFosSpeed 7.01 Build 1940 Beta.
  7. The Following 3 Users Say Thank You to anhnn2010 For This Useful Post:
    anhnn2010's Avatar
    Jan 2011
    Re: cFosSpeed 7.00 Build 1901 Final/ 7.01 Build 1941 Beta [25.04.2012]
    Cập nhật Cập nhật cFosSpeed 7.01 Build 1941 Beta.
  9. The Following 4 Users Say Thank You to anhnn2010 For This Useful Post:
  10. #6
    Moderator
    Re: cFosSpeed 7.00 Build 1901 Final/ 7.01 Build 1942 Beta [27.04.2012]
    Update cFosSpeed 7.01 Build 1942 Beta
    Pass: softvnn.com
  11. The Following 3 Users Say Thank You to forvutien For This Useful Post:
  12. #7
    Moderator
    Re: cFosSpeed 8.00 Build 1946 Final/ 8.01 build 1963 Beta [28.05.2012]
    Pass: softvnn.com
  13. The Following 4 Users Say Thank You to forvutien For This Useful Post:
  14. #8
    thaygiaoonline Đang Ngoại tuyến Thành viên mới
    Mar 2012
    Trích dẫn Gửi bởi forvutien [Only registered and activated users can see links. ]
    bạn chủ topic thân mến!
    Nếu bạn có thể , ngoài phần mềm này ra , bạn có thể chỉ cho chúng tôi biết cách tinh chỉnh các tùy chọn để phần mềm này hỗ trợ tốt nhât ko.
    Rất mong sự giúp đỡ của bạn.
    cảm ơn bạn!
  15. #9
    Moderator
    Thật ra mình xài phần mềm này cài vào cũng chỉ để mặc định thôi bạn à ^^ Như vậy cũng đủ giúp cho mạng của mình hoạt động khá ổn định.
    Pass: softvnn.com
  16. #10
    cuocdoilangtu Đang Ngoại tuyến
    May 2011
    bien hoa
    rất thích xài cái này nhưng để cho đẹp thôi chứ mình cũng không bít công dụng của nó thế nào
  17. The Following 2 Users Say Thank You to cuocdoilangtu For This Useful Post:
  18. #11
    vodailam's Avatar
    vodailam Đang Ngoại tuyến Thành viên Softvnn
    Somewhere I Belong
    Trích dẫn Gửi bởi cuocdoilangtu [Only registered and activated users can see links. ]
    Sự thật thì không hiệu quả mấy đâu. Trước kia mình có thời cập nhật theo phần mềm này mệt nghỉ, sau này, thấy không tăng tốc độ được bao nhiêu nên bỏ luôn.
    L.I.F.E Is
    Love :lovelove: Is
    For Ever
  19. #12
    May 2011
    bien hoa
    Re: cFosSpeed 8.00 Build 1946 Final/ 8.01 build 1966 Beta [04.06.2012]
    link thuốc die rồi.......
  20. #13
    Vicky_Kipi's Avatar
    Vicky_Kipi Đang Ngoại tuyến Thành viên Softvnn
    Jun 2010
    Hải Phòng
    http://www.mediafire.com/?tbehb7d0wv5ca62
    :lovelove: Bông ngố ơy là ngố :lovelove:
  21. The Following 3 Users Say Thank You to Vicky_Kipi For This Useful Post:
  22. #14
    anhsaobang1456's Avatar
    anhsaobang1456 Đang Ngoại tuyến Thành viên mới
    Jun 2012
    Huế, Việt Nam
    Trích dẫn Gửi bởi vodailam [Only registered and activated users can see links. ]
    Không phải là tăng tốc độ bạn à. ví dụ mạng bạn 3Mb thì down IDM tẹt ga cũng chỉ 340~350kbps/s chứ mấy, tăng sao được nữa, cái chính là cFosSpeed nó tối ưu đường truyền cho mình, khi có nhiều kết nối internet đồng thời với nhau, tránh tình trạng tắc nghẽn thôi (dựa vào setting của mình, cho cái nào high, cái nào higher thôi...
    Các bạn chú ý, trong phần Preferences xem thử RX LimitTX Limit của mình đã max theo gói mạng của mình chưa, nếu ko thì phải định tuyến lại đường truyền cho max, kẻo lại bảo nó làm chậm mạng
    Lần sửa cuối bởi anhsaobang1456, ngày 16-06-2012 lúc 11:34 AM.
    Nobody can stop my love for you Westlife.
    I always love you more and more than yesterday
  23. The Following 5 Users Say Thank You to anhsaobang1456 For This Useful Post:
  24. #15
    anhnn2010's Avatar
    Jan 2011
    Re: cFosSpeed 8.00 Build 1946 Final/ 8.01 build 1968 Beta [21.06.2012]
    Cập nhật 8.01 Build 1968 Beta.
  25. The Following 3 Users Say Thank You to anhnn2010 For This Useful Post:
cfosspeed, internet, traffic, data, shaping, ping, download, improve, beta, access, games, online, mobile, existing, isdn, umts, cable, 8.02, build, and/or, connections, changelog, protocol, prioritization, program, configure, packets, times, calls, chat, play, files, unimportant, prioritized, automatically, simultaneously, important, transfering, cfosspeeds, homepage, explanation, detailed, trang, tutorial, manual, reset, 4.39mb, final, 8.03, 4.63mb 4.5 5 81445
