WinBin2Iso Portable 1.64.92 Build 001
WinBin2Iso Portable description
Converts BIN to ISO images also for files over 2GB
WinBin2Iso is a lightweight and extremely easy to use software utility that converts BIN CD images to ISO format.
WinBin2Iso requires no installation and can be carried on a small usb-stick or other memory device.
Requirements:
· CPU: 200 MHz
What's New in This Release:
· New language in "Win Bin 2 Iso": French
· General optimization in WinBin2Iso
Download:
http://www.softpedia.com/progDownload/WinBin2Iso-Portable-Download-189453.html
winbin2iso, portable, images, converts, small, device, usb-stick, memory, requirements, general, optimization, download, http://www.softpedia.com/progdownload/winbin2iso-portable-download-189453.html, french, release, language, requires, files, http://i1-win.softpedia-static.com/screenshots/winbin2iso-portable_1.png, 1.64.92, build, description, lightweight, extremely, format, installation, easy, software, utility, carried 4.5 5 183
