    G-Max's Avatar
    G-Max Đang Ngoại tuyến
    Vietnam
    [MS] Portable UltraISO Premium Edition 9.5.0.2800 DC 21.10.2011 (22-10-2011)
    BÀI VIẾT DỰ THI "SOFTVNN IDOL 2011"
    Along with large capacity hard disk popularity, people were already used to coping compact discs to CD/DVD image files (also called compact disc image document) , generally used is the famous ISO 9660 international standards format, therefore CD/DVD image files are called ISO files.
    Because the ISO file retained complete data information of the compact disc (including compact disc boot information), you were allowed the convince to use commonly used CD burning software (for example Nero-Burning ROM ) to record the disc with your CD-R/RW over and over forever, it can also be used directly through Virtual CD-ROM drive software (for example SoftDisc ) .
    UltraISO is a CD/DVD image file creating/editing/converting tool , it can directly edit the CD/DVD image file and extract files and folders from it, as well as directly make ISO files from your CD/DVD drive or hard disk. At the same time, you can maintain the ISO bootable information, thus creating your own bootable CDs and DVDs. You now have the power to make and edit your own ISO files, and then burn them to CD or DVD for your own needs.
    UltraISO is in sole possession of the intellectualized ISO document format analyzer, it can process at the present time almost all types of image files, including ISO and BIN, it may even support new image files which are yet to be created. UltraISO can open these image files, directly extract files and folders, edit it and convert other image files to the standard ISO format.
    UltraISO uses the double window unification user contact interface, you have the choice to only use the quick buttons and/or the mouse Drag & Drops, you can handle any CD/DVD image file easily.
    Here are some key features of "UltraISO Media Edition":
    · Can directly edit the ISO image file.
    · Can directly extract files and folder from ISO image file
    · Can add / delete /create new directory /rename ISO file image content.
    · Can make ISO file from hard disk document.
    · Can create CD image from CD/DVD-ROM, maintain bootable information.
    · Can process the compact disc boot information, you can directly add/remove/extract boot image of the ISO image.
    · Supports nearly all known CD image file formats (.ISO, .BIN, .IMG, .CIF, .NRG, .BWI and so on) , and converts them to the standard ISO form image.
    · May directly set the file/folder to hidden attribute
    · Supports ISO 9660 Level1/2/3 and Joliet extension
    · Automatically optimizes the ISO image file structure, saves the CD space.
    · Supports the shell document type integration, Open Image files through double clicking them or the Right Click menu of the mouse with the open dialog.
    · The double window user interface is extremely convenient to use.
    · There are rich add-on tools, you can create ALL in 1 bootable compact discs, CD image file management, even the virtual CD/DVD drive , those functions are really powerful.
    Operating System: Windows 7, 2000, XP, and Vista. 32/64bit version
    HOMEPAGE
    Megashare |3.25 MB
    Password unrar: softvnn.com
    SOFTVNN IDOL 2011 - 10 ĐIỂM
    Lần sửa cuối bởi CheChơn, ngày 15-11-2011 lúc 09:05 AM.
  2. The Following 7 Users Say Thank You to G-Max For This Useful Post:
image, files, file, directly, cd/dvd, ultraiso, compact, information, disc, document, edit, bootable, boot, double, supports, edition, make, extract, format, drive, open, disk, hard, 2011, premium, create, mouse, 9.5.0.2800, virtual, folders, time, maintain, portable, process, user, including, called, idol, standard, window, 21.10.2011, softvnn, software, interface, 9660, discs, add/remove/extract, features, /rename, converts 4.5 5 2963
