    nhanngoquyen's Avatar
    nhanngoquyen Đang Ngoại tuyến Resetting ...
    Cánh đồng bất tận
    Revo Uninstaller Pro 2.5.7/ Revo Uninstaller 1.93 [05.12.2011]
    Revo Uninstaller Pro 2.5.5
    Revo Uninstaller - innovative freeware uninstall utility. Uninstall, delete, remove programs and solve uninstalling problems.
    Revo Uninstaller helps you to uninstall and remove unwanted programs installed on your computer even if you have problems uninstalling and cannot uninstall them from "Windows Add or Remove Programs" control panel applet. Revo Uninstaller is a much faster and more powerful alternative to "Windows Add or Remove Programs" applet!
    With its advanced and fast algorithm, Revo Uninstaller analyzes an application's data before uninstall and scans after you uninstall an application. After the program's regular uninstaller runs, you can remove additional unnecessary files, folders and registry keys that are usually left over on your computer. Even if you have a broken installation, Revo Uninstaller scans for an application's data on your hard disk drives and in the Windows registry and shows all found files, folders and registry keys so you can delete them.
    With its unique "Hunter mode", Revo Uninstaller offers you some simple, easy to use, but effective and powerful approaches to manage (uninstall, stop, delete, disable from auto starting) and to get information about your installed and/or running programs.
    Revo Uninstaller gives you another 8 handy and powerful tools to clean up your system.
    Here is the list of the tools and utilities included in Revo Uninstaller:
    • Auto Start Manager - Stop programs that start automatically on Windows startup; speed up loading of Windows!
    • Windows Tools Manager - Handy and useful tools bundled with every version of Windows; easily find useful system tools and options!
    • Junk Files Cleaner - Find and remove unnecessary files from your computer; free up disk space and delete files you do not need!
    • Browsers History Cleaner - Erase web browser history, visited pages history and temporary internet files of Internet Explorer, Firefox, Netscape and Opera web browsers; free up a lot of disk space by deleting temporary internet files like temporary saved videos, temporary flash files, temporary pictures etc!
    • Office History Cleaner - Remove the history of most recently used files in MS Office; remove your tracks by deleting the list of last opened MS Office documents!
    • Windows History Cleaner - Remove the history of recently opened files, delete temporary files, remove usage tracks and other history items that are saved by Windows; remove your tracks saved by Windows for a lot of operations!
    • Unrecoverable Delete Tool - Erase files and folders forever; be sure that nobody could recover your files and folders after deleting!
    • Evidence Remover - Make sure already deleted files, folders and other data are unrecoverable; securely erase your data!
    • Revo Uninstaller Pro is compatible with the following operating systems: Windows XP, Windows 2003, Windows Vista and Windows 7
    • Revo Uninstaller Pro has full native support of 64bit operating systems!
    What's new in Revo Uninstaller Pro 2.5.7:
    • Fixed minor bugs
    Password unrar : softvnn.com
    Lần sửa cuối bởi anhnn2010, ngày 05-12-2011 lúc 09:13 PM. Lý do: cập nhật, bổ sung ^^!
  2. The Following 8 Users Say Thank You to nhanngoquyen For This Useful Post:
    anhnn2010's Avatar
    anhnn2010 Đang Ngoại tuyến Thành viên lão làng
    Jan 2011
    Re: Revo Uninstaller Pro 2.5.7/ Revo Uninstaller 1.93 [05.12.2011]
    Cập nhật Revo Uninstaller Pro 2.5.7.
    Trích dẫn Gửi bởi wakata [Only registered and activated users can see links. ]
    Đừng ngại ngần, hãy đi!
uninstaller, revo, windows, files, remove, history, programs, uninstall, temporary, delete, tools, folders, data, cleaner, powerful, disk, office, erase, deleting, internet, saved, computer, tracks, registry, systems, keys, operating, johnwho, recently, stop, handy, unrecoverable, auto, 2.5.7, thuốc, start, list, system, manager, uninstalling, applet, download, installed, space, phần, [revo, free, scans, problems, browsers 4.5 5 4732
