    tuan.cse06's Avatar
    tuan.cse06 Đang Ngoại tuyến
    -= Biệt Thập =-
    Lapland
    SpyHunter 4.5.11.3608 [15.08.2011]
    SpyHunter v4.0
    Stop Trojan & Spyware from invading your PC!
    SpyHunter is a powerful, real-time anti-spyware application certified by West Coast Labs’ Checkmark Certification System and designed to assist the average computer user in protecting their PC from malicious threats. SpyHunter is automatically configured out of the box to give you optimal protection with limited interaction so all you need to do is install it for immediate and ongoing protection.
    As malware continues to evolve and become more sophisticated to avoid detection by anti-spyware/anti-virus programs, SpyHunter responds with new advanced technology to stay one step ahead of today’s computer threats.
    SpyHunter’s latest version (v.4) has added a variety of advanced protection features to detect the latest parasites while keeping you actively protected. SpyHunter takes it a step further by offering additional customization capabilities to ensure every user is able to custom tailor SpyHunter to fit their specific needs.
    SpyHunter has the ability to detect and remove rootkits, which are used to stealthy install rogue anti-spyware programs and other trojans. Rootkits use hidden and encrypted folders to avoid detection by traditional security software. SpyHunter’s newly integrated advanced rootkit detection technology allows it to perform an instant rootkit scan and promptly display a message upon detection. The message will ask the user to reboot the computer and after reboot the rootkit will have been removed.
    In order to completely remove rootkits, Windows must be stopped upon boot because rootkits utilize other files that load and run with Windows. Therefore, to prevent rootkits from regenerating on a user’s computer, we’ve added a Compact OS into SpyHunter that allows your system to be booted without Windows so that the rootkit may be removed.
    If SpyHunter’s automated malware removal fails, Spyware HelpDesk, an interactive feature intergrated into SpyHunter, allows our technicians to analyze your machine and create custom fixes to specific malware problems that may be unique to your machine and conveniently transmit the fixes directly to your SpyHunter program. This feature is not only significant for detecting difficult malware, but it allows us to provide you with the optimal technical support to ensure that your system is free from rootkits, trojans, worms, spyware, rogue anti-spyware programs, and other computer threats.
    Benefit:
    • Detect, remove and block thousands of spyware, rootkits, adware, keyloggers, cookies, trojans, worms and other types malware.
    • New! Integrated SpyHunter Compact OS to aid in removal of rootkits and other stubborn malware parasites.
    • New! System Guards will identify and stop any processes that attempt to secretly auto-start malware entries by exploiting the Windows registry.
    • New! Exclusions feature allows you to exclude certain programs from being detected in future SpyHunter scans.
    • Interactive one-on-one customer support service called Spyware HelpDesk.
    • New spyware definitions updates added daily to ensure complete protection from the latest malware trends.
    • Easy to use interface with intelligent automatic protection.
    • Custom malware fixes specific to your computer’s spyware problems. SpyHunter’s Spyware HelpDesk creates a diagnostic report that is analyzed by our technicians, and an automated custom fix generated from the report is sent back to you via SpyHunter.
    Key Features:
    SpyHunter Scanner
    SpyHunter has been carefully engineered to be powerful and complete enough for the most demanding technical professional, yet simple enough for a first-time computer user to safely and effectively utilize. With just a simple click, SpyHunter Scanner will scan your computer’s memory, registry, cookies, and files. Items found to be infected will then be listed for you.
    To find out more information about a specific object, merely select it. When you are ready to remove any infected files, all you have to do is check the box next to the item and hit the “Start Remove” button. All objects that you remove are then placed in SpyHunter’s quarantine area. Simple as that!
    System Guards
    SpyHunter features an improved System Guards feature that integrates several proactive protection elements into one integrated panel. SpyHunter’s new System Guards automatically blocks malicious process from executing and running on your system. System Guards incorporates guards against Active X control, Registry protection and Process control. Each of these built-in functions provides computer users with automated parasite blocking capabilities.
    The System Guards Process feature is designed to give you complete control over which processes are authorized to run on your system and allow you to identify and stop malicious processes before they are executed. Using System Guard, you are able to allow certain processes to run, while blocking those do might feel are malicious or unnecessary. A list of processes is available to you to edit as you see fit.
    Spyware HelpDesk
    New to SpyHunter, is the Spyware HelpDesk, a unique and highly effective interface through which you can contact our support department to solve any malware related issues for absolutely free! The Spyware HelpDesk consists of two separate sub-systems: the SpyHunter Support Ticket System, and the Custom Fix System.
    If you experience any issues with SpyHunter whatsoever, or have any questions, comments or suggestions related to SpyHunter, we strongly encourage you to utilize the SpyHunter Support Ticket System. If SpyHunter is unable to remove an infection from your computer, our technical support department will be happy to generate a customized fix for you, which can be run through SpyHunter to eradicate any infections lurking on your system. Please note, however, that these services are only available with the FULL version of SpyHunter.
    Custom Scan
    SpyHunter includes a new feature called Custom Scan. Custom Scan allows you to save time by limiting your scan to specific sections of your computer. With SpyHunter’s Custom Scan, you will be able to select the following scan types: Memory, Registry, Cookies, Files or Rootkits.
    A Custom Scan may only take a fraction of the time than a Full Scan would require. Even though a Custom Scan may not catch some residuals, it is an excellent choice for occasional system scans when you are trying to save time.
    Backup
    Included as part of SpyHunter’s new scan functions, is an easy and convenient Backup feature that allows you to restore backed up objects using the rollback feature. In the event that an object is removed by SpyHunter, you can choose to restore the object using the built-in rollback feature. The selected object will be restored to its original location as if it was never removed by SpyHunter.
    Exclusions
    New to SpyHunter is an Exclusions Panel. The Exclusions feature in SpyHunter allows you to select objects that you wish to exclude from detection in future SpyHunter system scans. In some cases, SpyHunter may detect programs that you do not desire to remove. In this case, the exclusions panel will allow you to exclude individual programs from being identified. Once selected, the programs selected in the exclusions list will not be included or detected in any future scan processes.
    When you are ready to add an item to the Exclusions list, it is very easy to do, simply right-click on a detected item in the SpyHunter Scanner results and select “Add to Exclusions”. Removal of an item in the exclusions list is just as easy, simply select the checkbox next to the item that you wish to remove and then click the “Remove” button.
    General Settings
    SpyHunter’s new Settings panel was designed with you in mind. The General Settings panel offers several ways to customize the operation of SpyHunter for a more personalized experience, as well as giving you activation instructions in order to register for the full version of SpyHunter. Along with this, the following General Settings can be modified through the Options panel:
    • Automatically check for updates – SpyHunter will automatically contact the Enigma Software Group servers to check for the availability of new program and definitions updates each time it starts.
    • Automatically download and install definition updates – SpyHunter will automatically download and install any available definition file updates.
    • Start SpyHunter Security Suite on Boot – SpyHunter will be configured to automatically load each time you boot your computer.
    • Start SpyHunter Scan on Boot – SpyHunter will automatically start and begin scanning your machine each time you boot your computer.
    • Minimize Security Suite on startup – SpyHunter will start minimized, visible only as a taskbar icon. SpyHunter’s real-time protection features will still operate at full capacity.
    • Prompt if any important windows components are disabled – SpyHunter will monitor your Windows settings and prompt you if a process attempts to disable the task manager or other important Windows components.
    • Prompt if web content is used on desktop – SpyHunter will monitor Windows settings and prompt you if active web content is being used on your desktop.
    Network Sentry
    SpyHunter’s Network Sentry is included within the Settings panel area. The Network Sentry is designed to give you complete control over your system networking settings, and to prevent malicious objects from modifying and disrupting your Internet connection. In addition to HOSTS file protection, SpyHunter also offers an option to protect other Windows system files from unauthorized modification. These can be manually selected by the user, offering you a lot more control over what you wish to keep safe.
    SpyHunter also contains advanced functionality designed to prevent malware from hijacking your desired Internet Explorer homepage. Lastly, SpyHunter can be configured to monitor your DNS servers and notify you if an unsolicited modification takes place. This prevents tricky Trojan and malware organizations from redirecting you to a phishing or malware site.
    Scan Scheduler
    SpyHunter’s Scan Scheduler can be setup and easily configured through the Scan Scheduler area under the Settings panel. The advanced Scan Scheduler feature allows you to run a complete SpyHunter scan at a pre-set time, even if you are away from your computer. Easy to access and use, the Scan Scheduler allows you to pre-set the scan time at daily, weekly and monthly intervals.
    If you opt for the daily scan, you can choose to run the scan every day, every other day, every weekday, or at any interval of days that you choose. If you choose the weekly scan, you will be able to select the day of the week that your scan will be scheduled for and for the monthly scan, select the day of the month that your scan will be scheduled for. Please note that your computer must be powered on at the time that your scan is scheduled to run. If the computer is not turned on, the scan cannot execute!
    SpyHunter Full Version Information:
    • Current Version: 4
    • File Size: 14.4 MB
    • Operating System: Designed for Windows XP/Vista/7.
    • Release Date: April 12, 2010.
    • Protection Against: Spyware, Adware, Spyware Trojans, Keyloggers, Identity Theft, Hijackers, Tracking Threats, Malware, Worms, Rogue Anti-Spyware, Unwanted Software, Phishing, Popups and Malicious Websites.
    HOMEPAGE
    Download Trial
    Thuốc | Mirror 1
    Thuốc | Mirror 1
    (Đổi đuôi file từ .svnn sang .rar rồi giải nén với password: softvnnDOTcom)
    Ta đã trở lại.... Ăn hại gấp đôi.......
  2. The Following User Says Thank You to tuan.cse06 For This Useful Post:
    Tran Quang Ha's Avatar
    Tran Quang Ha Đang Ngoại tuyến Thành viên năng động
    Re: SpyHunter 4.5.11.3608 [15.08.2011]
spyhunter, scan, system, malware, computer, spyware, spyhunter’s, feature, custom, protection, windows, rootkits, settings, time, remove, exclusions, automatically, panel, select, programs, guards, support, helpdesk, processes, malicious, designed, version, advanced, control, specific, easy, files, full, boot, updates, complete, scheduler, item, user, detection, rootkit, choose, selected, list, registry, trojans, file, install, anti-spyware, threats 4.5 5 1889
