Trang 1 của 6 1 2 3 4 ... CuốiCuối
Kết quả 1 đến 15 của 82
    playboy6006's Avatar
    playboy6006 Đang Ngoại tuyến .: Mỹ Hầu Vương :.
    ♥ Đảo Khỉ ♥
    BitDefender All Home Products 2012 v15.0.38.1605 [21.04.2012]
    ---oOo---
    BitDefender Antivirus Plus 2012
    Essential Client Security
    Defend Yourself With The #1 Ranked Antivirus Protection!*
    Bitdefender capitalizes on live and virtualized behavior-based detection, in addition to cloud-based services, to stop emerging e-threats that other products miss.
    *#1 ranking based on reviews of Bitdefender Internet Security 2012 from: Top Ten Reviews, AV Test, Choice Magazine, ConsumerSearch.com and Which? Magazine (UK).
    Autopilot
    The Autopilot provides a hassle-free experience by making optimal security-related decisions without input from you. This means no pop-ups, no alerts, nothing to configure.
    Key-Features:
    • Defends against viruses and spyware
    • Halts ID theft attempts
    • Filters the links you receive from your Facebook and Twitter friends
    • Gives advance warning of risky websites
    ---oOo---
    BitDefender Internet Security 2012
    Enhanced Silent Security
    Autopilot
    Key-Features:
    • Blocks viruses, spyware & spam
    • Keeps kids safe with cutting-edge parental controls
    • Firewall to guard your Internet connection
    ---oOo---
    BitDefender Total Security 2012
    Ultimate silent security
    Autopilot
    Key-Features:
    • Online backup
    • Tunes up your PC for optimal speed & performance
    ---oOo---
    Products Comparison:
    ---oOo---
    Recommended system requirements [All Versions]:
    • Microsoft Windows XP SP3 (32 bit) , Vista (SP2), Microsoft Windows 7 (SP1)
    • 2.8 GB free space (at least 800 MB on the system drive)
    • Intel CORE Duo (1.66 GHz) or equivalent processor
    • RAM:
      o 1GB (Windows XP and Windows 7)
      o 1.5 GB (Windows Vista)
    • Internet Explorer 7 or higher
    [Only registered and activated users can see links. ] (Chạy trong Safe Mode)
    [ Password UnRar: softvnnDOTcom ]
    Lần sửa cuối bởi anhnn2010, ngày 11-04-2012 lúc 11:03 PM. Lý do: cập nhật, bổ sung!
    :33: :33: :33: :33: :33: :33:
  2. The Following 11 Users Say Thank You to playboy6006 For This Useful Post:
    khoquamaoi Đang Ngoại tuyến Thành viên Softvnn
    Re: BitDefender All Home Products 2012 v15.0.27.312 (29.07.2011)
    đang xài 2011,bạn nào xài thử 2012 rùi cho biết kết quả nhe hjhj,thx playboy
    Mà bản này có điểm nào mới không bạn,tiếng anh mình ngu lắm hix
    vanthanhkbs Đang Ngoại tuyến Thành viên mới
    Re: BitDefender All Home Products 2012 v15.0.27.312 [29.07.2011]
    mình test trên 2 máy. 1 máy dùng BIt 2011 1 mày dùng avg free. Máy dùng bit bắt link IDM cực kém. chả hiểu sao. phải f5 mấy cái mới down được
    buitiendat Đang Ngoại tuyến Thành viên Softvnn
    Hàng mới. Test thôi, bản 2011 đã nhẹ rồi không biết bản này thế nào.
    Đã cài đặt và crack ngon lành bản BitDefender Antivirus Plus 2012, trông khá cool Thanks anh Bôi
    ruanho's Avatar
    ruanho Đang Ngoại tuyến Thành viên năng động
    Bác nào cài bản Total cho xem cái hình tí nào, mình dùng bản IS.
    Tran Quang Ha's Avatar
    Tran Quang Ha Đang Ngoại tuyến Thành viên năng động
    - Đã cài thử BIT IS 2012, chạy khá mượt ...không "nặng" quá mức như thiên hạ đồn thổi.
    PhiHDN Đang Ngoại tuyến Thành viên mới
    Oct 2008
    Không biết bản 2012 có bị cái lỗi làm mạng chậm đi như 2011 không nữa
    Trích dẫn Gửi bởi PhiHDN [Only registered and activated users can see links. ]
    - Bản IS 2012 nếu để chế độ mặc định vẫn làm chậm mạng như thường bạn ạ.
    zorrotran's Avatar
    zorrotran Đang Ngoại tuyến Thành viên Softvnn
    đây
    Trích dẫn Gửi bởi Tran Quang Ha [Only registered and activated users can see links. ]
    Quan trọng là lướt web và download chậm còn hơn bản 2011
    enix Đang Ngoại tuyến Thành viên Softvnn
    Lang thang khắp các forum thấy ai cũng than thằng BIS 2012 này vẫn nặng, thôi thì ko dám từ bỏ KIS rồi ^.^
    Trích dẫn Gửi bởi enix [Only registered and activated users can see links. ]
    - Kas với Bit có khác gì nhau đâu, ảnh hưởng đến tài nguyên hệ thống gần như nhau bạn ạ.
    dackevil007 Đang Ngoại tuyến Thành viên Softvnn
    Ặc , vẫn còn , lỗi làm chậm mạng , cài bit2012 xong thì vào web chậm như rùa , tháo ra thì nhanh trở lại .... pó tay , quay lại với Avast thân yêu !!!!
    vannda's Avatar
    vannda Đang Ngoại tuyến Thành viên mới
    18 Re: BitDefender All Home Products 2012 v15.0.27.312 [29.07.2011]
    BitDefender nó chặn ko cho Down bằng Internet Download Manager vậy ?
    Pro nào biết chỉnh chỉ giùm mình với Thanks.....
    Trích dẫn Gửi bởi vannda [Only registered and activated users can see links. ]
    Đưa IDM vào loại trừ của BIT thử
    có nên xài 1 phần mềm hành hạ máy tính đến thế không nhỉ ?
không, nhanh, chậm, năng, search, giảm, trong, khoảng, phút, google, 2100, dùng, 4gb,đang, core, win7, thực, hoặc, truy, file, dung, mình, lượng, ultimate, cũng, mode, game, advisor, chức, thấy, nói,các, khỏi, avast,search, lướt, kill, tượng, hiện, post, trước, diễn, duyệt, 100mb, dụng, tình, trạng, update, load, suất, hiệu, việc, products 4.5 5 26367
