    tuan.cse06's Avatar
    tuan.cse06 Đang Ngoại tuyến
    -= Biệt Thập =-
    Lapland
    Coolutils Total PDF Converter 2.1.0.183 [28.06.2011]
    Total PDF Converter converts PDF to DOC, RTF, XLS, HTML, BMP, JPEG, GIF, WMF, EMF, PNG, EPS, PS, TIFF, TXT, CSV, PDF in batch. It is good for everybody who needs to convert a lot of PDF files but has no time to read user manuals. Unlike other batch PDF converters Total PDF Converter is extremely user-friendly due to a well-planned interface. Users can rely on predefined settings or use their own values. Converting large numbers of PDF files it's is importnat to avoid mess. Total PDF Converter keeps folder structure so you get the output files in perfect order. In addition to this, registered users get command line support to manage the utility with maximum efficiency. The unique options of Total PDF Converter include:
    • Total PDF Converter can convert multi-page PDF files to HTML/DOC/XLS/RTF/CSV/PS in batch and place each page into a separate file.
    • The tool will also give you the option of starting page numbering of the output file from any numbers (e.g. "6,7,8", not just "1,2,3").
    • Imagine you have to get all odd pages from a PDF file and combine them into one JPEG image. Or you want to turn every page of a multi-page PDF file into TIFF. With Total PDF Converter you can do that in
    Key Features:
    • Converts PDF to Doc, Excel, HTML, PS or Text
    • Converts PS, EPS, PRN files
    • Batch conversion mode
    • Converts PostScript to PDF
    • No need to use Adobe Acrobat
    • Supports PDF written in multi-byte Languages
    • Command line support
    • Preserves original document layout
    • Vista compatible
    HOMEPAGE
    Download
    Thuốc
    0y1WvtUD2Tvu/YCL6xLsaSEyKO0AbM1lBPIxPVwsLLAuv7+VgdoeMEpgz+Czszv6kFtgfi4cntW3sC6068CkxdZKOEUfe2i9B28M/sztjcCRwXIi3Q4EfOHYhbwZ6Y9atMUTfUNScaDmks1w5eEepA5sYPcf5+aC++qqlhdW3LlI
    Ta đã trở lại.... Ăn hại gấp đôi.......
  2. The Following User Says Thank You to tuan.cse06 For This Useful Post:
183, chuyển đổi, converter, coolutils, pdf, phiên bản mới, total, files, batch, converts, file, page, users, multi-page, support, line, numbers, convert, command, output, jpeg, tiff, html, 2.1.0.183, imagine, 1,2,3, image, combine, pages, 6,7,8, separate, give, tool, option, starting, numbering, http://farm6.static.flickr.com/5309/5880887836_e9b63791bd_o.jpg, [28.06.2011], original, document, preserves, languages, written, multi-byte, layout, vista, thuốc, 0y1wvtud2tvu/ycl6xlsaseyko0abm1lbpixpvwsllauv7+vgdoemepgz+czszv6kftgfi4cntw3sc6068ckxdzkoeufe2i9b28m/sztjccrwxii3q4efohyhbwz6y9atmutfunscadmks1w5eeepa5sypcf5+ac++qqlhdw3lli, download, homepage 4.5 5 1124
