PDF-XChange Viewer is an alternative viewer for PDF files that enables you to view and annotate PDF files. You can add text, sticky notes, and other annotations and save them to the file, which will be compatible with the standard Adobe PDF reader. The program also includes a handy loupe tool to zoom in on selected areas of a document, as well as options to extract text and images, export a documents to image formats, and more.
PDF-XChange Viewer offers a modern, tabbed interface and an attractive set of features. The FREE PDF-XChange Viewer offers all the feature's you would expect such as support of all PDF file formats from Version 1.0 all the way to the latest 1.7 (Acrobat 8). You might be surprised just how quickly your large PDF files open and pages smoothly refresh as they are scrolled. So, why not speed up and improve your PDF Viewing experience by downloading the free PDF-XChange Viewer now!
Those wishing to view PDF files on their Windows PC's now have a choice when it comes to Viewing PDF files - the PDF-XChange Viewer is smaller, faster and more feature rich than the Adobe Reader which has until now been the Reader of choice for PDF files - we think that's about to change !
Features:[Free Edition]
• Add Comments and Annotations to any PDF file (subject to security settings) - unlike the Adobe Viewer which requires the PDF creation tool to be 'certified' by Adobe !
• Add & apply Custom Stamps from any Image or PDF File and even your Windows Clip board !
• Mark-up pages with text and objects
• Type directly on any PDF page, not just Adobe enabled forms documents - in Typewriter mode.
• Export PDF pages or entire files to any one of the supported Image formats including BMP, JPEG, TIFF, PNG and many more ...
• Extract text from a PDF page/File
• Make your navigation of large or complex PDF files both simple and enjoyable with the extended functionality of our 'Loupe' and the 'Pan' Window tools
• Fill and Save Adobe Forms to disk, email or 'post' !
• Full javascript Engine included
• Updated JPEG2000 Compression support - improving speed.
• Plug-Ins for both MS IE or Firefox Browser's included
• Integrate seamlessly with your favourite translation software to translate text on the 'fly' - including : ABBYY Lingvo 12, Translate It!, Lingoes.
• Includes comprehensive Help file and PDF Manual - no extra downloads required to add features etc.
• Portable version also available - can be run from any suitable device such as a Memory stick/CD/DVD etc - simply unzip and use - no installation required - just 4MB download !
• And many more features such as Rotate and 'Save', Email files etc ...
Changes in version 2.5.0195.0:
- Fixed crash when opening some XFA-files. (T#957, T#968)
- Fixed behaviour when document is opened from LAN (or from removable storage) when the connection has been lost.
- Fixed issue with /importp command-line parameter. (T#984) (10539)
- Exclusive commenting mode: fixed behaviour for right clicking.
- Resolved issue with printing rectangles with zero width or height. (T#969)
- Added two new events "Notifications.BeforeCloseDoc" and "Notifications.DocClosed".
- Fixed grammar on resume message when returning from suspend. (T#963)
- Resolved issue with unicode subject on Send by Email. (10497)
[Only registered and activated users can see links. ]| Free | 13.84MB
[Only registered and activated users can see links. ]| Pro | 29.23MB
[Only registered and activated users can see links. ]| Standard | 6.15MB
[Only registered and activated users can see links. ]| Lite | 4.75MB
License: Pro
Serial : PXP40-4O031-1514Y-KRJM6-6A6E8-6WLE2
Từ hồi chuyển từ Adobe Reader sang cái này, mình ko dùng bất kì cái nào khác nữa. Đã dùng thử qua hầu hết phần mềm khác rồi, phải nói thằng này là nhất đó!
Đẹp + Nhanh + Ít hao tài nguyên!
Nó check online mà, key nào cũng thế thôi. Thực tế thắn này thua xa Adobe Reader, vì thằng Adobe Reader nó có 1 service giúp load nhanh file PDF, những file PDF nặng thì Adobe Reader mở nhanh vô đối, Foxit reader hay thằng này chỉ là cóc ghẻ xạo thôi
Key bác đưa không dùng được cho build 194 đâu, chỉ activated cho build 192 thôi. Mình rất thích phần mềm này, nhanh đẹp chiếm ít tài nguyên và đặc biệt là khi đọc file pdf nó tự động lưu lại vị trí đã đọc trước đó.
The Following User Says Thank You to dongtinh For This Useful Post:
