SONY Sound Forge Pro 10.0c Build 491 (Full Repack) + Noise Reduction
SONY Sound Forge Pro 10.0c Build 491 (Full/Repack) + Noise Reduction | 178 MB
Sound Forge Pro 10 software efficiently and reliably provides audio editors and producers complete control over all aspects of audio editing and mastering. Whether in the studio or field, it's the ultimate all-in-one production suite for professional audio recording and mastering, sound design, audio restoration, and Red Book CD creation. New features in Sound Forge Pro 10 include precise event-based editing, integrated disc-at-once CD burning, musical instrument file processing, and pristine audio conversion and time stretching.
Features:
Supports 24-bit and 32-bit/64-bit float 192 kHz files
Edit mono, stereo, and multichannel audio files (up to 32 channels)
Over 20 real-time DirectX plug-ins
Multichannel file editing and processing
Real-time editing and processing
Automated time-based recording
ASIO driver support
Customizable keyboard mapping
DirectX audio plug-in support
VST audio effect support
Video and AVI support
Unlimited undo/redo levels
Drag-and-drop editing between channels
Integrated disc-at-once CD burning
Full support for 4GB + files
And much, much more...
New features:
New customizable window layouts
New default fade types
New tabbed user interface
New performance optimizations
New event-based editing
New musical instrument file processing
New metadata windows
Enhanced Broadcast Wave Format (.bwf) support
New filters and DirectX plug-ins
Effects
New! Includes Mastering Effects Bundle 2 powered by iZotope
New! Zplane ***233;lastique Pro timestretch and pitch shift DirectX plug-in
New! Resonant Filter plug-in
VST plug-in effect support
DirectX plug-in effects automation
DirectX Plug-in Manager
Real-time effects previewing
Modeless audio Plug-In Chainer
Wet/dry mix and crossfade options
Acoustic environment simulator
Amplitude Modulation
Chorus
Distortion
Delay/Echo (Simple and Multi-Tap)
Graphic Dynamics
Multi-Band Dynamics
Envelope
Flange/Wah-Wah/Phaser
Gapper/Snipper
Noise Gate
Pitch Bend/Shift
Reverb
Vibrato
Wave Hammer Compressor/Volume Maximizer
Notable fixes/changes in Version 10.0c
- Fixed a bug that could cause the spectrum graph to be displayed incorrectly in the Spectrum Analysis window.
- Fixed a crash that could occur when an in-use file was modified outside of Sound Forge 10.
- Fixed a crash that could occur when dragging a selection to the workspace to create a new file.
- Fixed a crash that could occur when loading a sample via SDMI.
- Fixed a bug that could cause Sound Forge to hang or crash when using the Batch Converter script on a large number of files.
- Fixed a bug that could delay plug-in parameters from being updated in real time during looped playback.
- Fixed a bug that caused a Find operation to change the active editing tool.
- Fixed a bug that prevented you from editing the Selection Start, Selection End, and Selection Length boxes on a data window when using SMPTE Drop time.
- Fixed a bug that prevented the SMPTE: Play at Time trigger in the Playlist from working.
- Fixed a bug that could prevent Sound Forge from removing temporary files, incorrectly displaying the Crash Recovery dialog the next time you start the application.
Download from fileserve.com
http://www.fileserve.com/file/zUVTUvZ/SSF 10.0c Build 491.rar
Download from filesonic.com
http://www.filesonic.com/file/36261309/SSF 10.0c Build 491.rar
Download from uploading.com
http://uploading.com/files/14ma2412/SSF 10.0c Build 491.rar/
code, download, driver, file, full, include, integrated, pro, professional, ultimate, video, fixed, audio, sound, plug-in, editing, forge, support, 10.0c, directx, build, files, time, crash, processing, selection, effects, noise, real-time, burning, window, disc-at-once, occur, reduction, sony, features, mastering, 491.rar, prevented, start, customizable, wave, channels, spectrum, plug-ins, multichannel, effect, incorrectly, pitch, smpte 4.5 5 1543
