[Multi] Vân Sơn Tuyển Tập Hài Full Collection (40 DVD)
Video info: (Disc 01)
General
Format : Matroska
File size : 1.00 GiB
Duration : 1h 15mn
Overall bit rate : 1 897 Kbps
Encoded date : UTC 2010-10-23 00:19:40
Writing application : mkvmerge v4.2.0 ('No Talking') built on Jul 28 2010 18:38:23
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Format settings, GOP : M=1, N=5
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 15mn
Bit rate : 1 411 Kbps
Width : 704 pixels
Height : 478 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.140
Stream size : 763 MiB (74%)
Writing library : x264 core 104 r1698 c41b8f0
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : VO (voice over)
Codec ID : A_AC3
Duration : 1h 15mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 242 MiB (24%)
Menu
00:00:00.000 : :Con gái - Vân Sơn, Thanh Trúc (Trích Từ DVD 4)
00:04:34.600 : :Lỡ thời - Quang Minh, Hồng Đào, Hoài Linh (Trích Từ DVD 6)
00:30:13.200 : :Vợ chồng mộng mơ - Vân Sơn, Phi Nhung (Trích Từ DVD 7)
00:40:34.767 : :Ăn mày - Vân Sơn (Trích Từ DVD 3)
00:43:03.833 : :Cha con - Út Mập, Bé Mập (Trích Từ DVD 5)
00:54:44.033 : :Hắc Bạch công tử - Vân Sơn, Hoài Linh, Hồng Đào, Út Mập, Bé Mập (Trích Từ DVD 6)
Download: Pass: all.hdvnbits.org
Torrent:
Disc 01 - 10: http://all.hdvnbits.org/van_son_tuyen_tap_hai_full_collection_40_dvd_ac3_x264_sdvb_disk_01_disk_10_t1919.html
Disc 11 - 20: http://all.hdvnbits.org/van_son_tuyen_tap_hai_full_collection_40dvd_ac3_x264_sdvb_t1986.html (Thiếu disc 17, sẽ bổ sung vào pack 3)
Disc 21 - 30 (bổ sung disc 17): http://all.hdvnbits.org/van_son_tuyen_tap_hai_full_collection_40dvd_ac3_x264_sdvb_all_hdvnbits_org_disk_21_disk_30_t2100.html
Mediafire: (Disc 1 - 10)
http://www.mediafire.com/?hdocnjs4d8put
Mega1280:
Disc 01 - 07: http://mega.1280.com/folder/CVYZR4E87I/
Disc 08 - 14: http://mega.1280.com/folder/KK8QZW64HA/
Disc 15 - 20: http://mega.1280.com/folder/5AGG13R01X/ (Thiếu disc 17, sẽ bổ sung ở box 3)
Disc 21 - 30: http://mega.1280.com/folder/JNXEJIDMCC/ (đã bổ sung disc 17)
Updating direct link và các disc còn lại.... View more the latest threads:
Lần sửa cuối bởi longndp, ngày 01-11-2010 lúc 08:10 PM.
The Following 2 Users Say Thank You to longndp For This Useful Post:
Re: [Multi] Vân Sơn Tuyển Tập Hài Full Collection 40 DVD
Cho Xin Pass giải nén rar , thanks
Mình có để ở tên đó bạn, Pass giải nén là all.hdvnbits.org
Tôi có thấy Pass này của Bạn ! Nhưng down xong 56 files rar bằng MF về máy mà không giải được bằng Pass này ? Mong Bạn chỉ giáo thêm. Cám ơn nhiều, tôi thích Hài Vân Sơn lắm, đang nóng ruột đây. Mong Bạn giúp cho. Thank a lot
Bác thử gõ lại từng ký tự xem, có thể do bác copy nên nó dư khoảng trắng ở cuối đấy
Update link bộ 2: từ disc 11 đến disc 20 (Thiếu tập 17, sẽ bổ sung ở pack 3): Code:
Link mega1280 từ disc 08 đến 14: Pass vẫn là all.hdvnbits.org
Rất cám ơn Bạn hướng dẫn tốt
Update 5 tập disc theo ( 15 ,16 ,18 ,19 ,20 ) (Disc 17 sẽ bổ sung ở box 3)
Update Disc 21 - 30 (bổ sung disc 17):
Update directlink:
ở, các, công, download, dvd, full, lại, multi, nhu, qua, tập, từ, tử, tuyển, vào, disc, format, trích, rate, sơn, vân, mập, sung, bổ, codec, duration, size, writing, settings, kbps, video, 15mn, thiếu, library, v1.0.0, display, pixels, linh, hoài, bits, ratio, sẽ, format/info, depth, Đào, hồng, stream, mode, audio, collection 4.5 5 3875
