    anhdoan.bn68 Đang Ngoại tuyến Thành viên Softvnn
    Mar 2010
    all samsung unlock code
    chào các bạn.
    đây là một số code dùng cho samsung khá là đầy đủ, các bạn tự ''vọc'' nhé. (cẩn thận khi dùng một số code cho từng đời máy không thì có thể làm cho máy bị lỗi),xin đừng trách các bạn nhé.
    *2767*688# = Unlocking Code
    *#8999*8378# = All in one Code
    *#4777*8665# = GPSR Tool
    *#8999*523# = LCD Brightness
    *#8999*3825523# = External Display
    *#8999*377# = Errors
    #*5737425# = JAVA Something{I choose 2 and it chrashed}][/b]
    *#2255# = Call List
    #*536961# = Java Status Code
    #*536962# = Java Status Code
    #*536963# = Java Status Code
    #*53696# = Java Status Code
    #*1200# = AFC DAC Val
    #*1300# = IMEI
    #*1400# = IMSI
    #*2562# = ??? White for 15 secs than restarts.
    #*2565# = Check Blocking
    #*3353# = Check Code
    #*3837# = ??? White for 15 secs than restarts.
    #*3849# = ??? White for 15 secs than restarts.
    #*3851# = ??? White for 15 secs than restarts.
    #*3876# = ??? White for 15 secs than restarts.
    #*7222# = Operation Typ (Class C GSM)
    #*7224# = I Got !! ERROR !!
    #*7252# = Oparation Typ (Class B GPRS)
    #*7271# = Multi Slot (Class 1 GPRS)
    #*7274# = Multi Slot (Class 4 GPRS)
    #*7276# = Dunno
    #*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
    #*2787# = CRTP ON/OFF
    #*3737# = L1 Dbg data
    #*5133# = L1 Dbg data
    #*7288# = GPRS Attached
    #*7287# = GPRS Detached
    #*7666# = SrCell Data
    #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
    #*7284# = Class : B,C or GPRS
    #*2256# = Calibration Info
    #*2286# = Battery Data
    #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
    #*2679# = Copycat feature (Activate or Deactivate)
    #*3940# = External loop test 9600 bps
    #*4263# = Handsfree mode (Activate or Deactivate)
    #*4700# = Half Rate (Activate or Deactivate)
    #*7352# = BVMC Reg value
    #*8462# = Sleeptime
    #*2558# = Time ON
    #*3370# = EFR (Activate or Deactivate)
    #*3941# = External looptest 115200 bps
    #*5176# = L1 Sleep
    #*7462# = SIM phase
    #*7983# = Voltage/Frequenci (Activate or Deactivate)
    #*7986# = Voltage (Activate or Deactivate)
    #*8466# = Old time
    #*2255# = Call ???
    #*5187# = L1C2G trace (Activate or Deactivate)
    #*5376# = ??? White for 15 secs than restarts.
    #*6837# = Official Software Version
    #*7524# = KCGPRS
    #*7562# = LOCI GPRS
    #*7638# = RLC allways open ended TBF (Activate or Deactivate)
    #*7632# = Sleep mode Debug
    #*7673# = Sleep mode RESET
    #*2337# = Permanent Registration Beep
    #*2474# = ???
    #*2834# = Audio Path
    #*3270# = DCS support (Activate or Deactivate)
    #*3282# = Data (Activate or Deactivate)
    #*3476# = EGSM (Activate or Deactivate)
    #*3676# = Flash volume formated
    #*4760# = GSM (Activate or Deactivate)
    #*4864# = Dunno doesn't work on newer versions
    #*5171# = L1P1
    #*5172# = L1P2
    #*5173# = L1P3
    #*7326# = Accessory (I got Vibrator)
    #*7683# = Sleep variable (8)
    #*7762# = SMS Brearer CS (Activate or Deactivate)
    #*8465# = Time in L1
    #*9795# = wtls key
    #*2252# = Current CAL
    #*2836# = AVDDSS Management (Activate or Deactivate)
    #*3877# = Dump of SPY trace
    #*7728# = RSAV done# (Everything went to standart but nothing was deleted)
    #*2677# = ARM State (None or Full Rate)
    *#8999*636# = Have no clue what it is, i see 20 lines
    *#9999# = Software version
    *#8999*8376263# = HW ver, SW ver and Build Date
    *#8888# = HW version
    *#8377466# = Same HW/SW version thing
    *#7465625# = Check the locks
    *7465625*638*Code# = Enables Network lock
    #7465625*638*Code# = Disables Network lock
    *7465625*782*Code# = Enables Subset lock
    #7465625*782*Code# = Disables Subset lock
    *7465625*77*Code# = Enables SP lock
    #7465625*77*Code# = Disables SP lock
    *7465625*27*Code# = Enables CP lock
    #7465625*27*Code# = Disables CP lock
    *7465625*746*Code# = Enables SIM lock
    #7465625*746*Code# = Disables SIM lock
    *7465625*228# = Activa lock ON
    #7465625*228# = Activa lock OFF
    *7465625*28638# = Auto Network lock ON
    #7465625*28638# = Auto Network lock OFF
    *7465625*28782# = Auto subset lock ON
    #7465625*28782# = Auto subset lock OFF
    *7465625*2877# = Auto SP lock ON
    #7465625*2877# = Auto SP lock OFF
    *7465625*2827# = Auto CP lock ON
    #7465625*2827# = Auto CP lock OFF
    *7465625*28746# = Auto SIM lock ON
    #7465625*28746# = Auto SIM lock OFF
    *2767*3855# = E2P Full Reset
    *2767*2878# = E2P Custom Reset
    *2767*927# = E2P Wap Reset
    *2767*226372# = E2P Camera Reset
    #*6420# = MIC Off
    #*6421# = MIC On
    #*6422# = MIC Data
    #*6428# = MIC Measurement
    #*3230# = Trace enable and DCD disable
    #*3231# = Trace disable and DCD enable
    #*3232# = Current Mode
    #7263867# = RAM Dump (On or Off)
    *2767*49927# = Germany WAP Settings
    *2767*44927# = UK WAP Settings
    *2767*31927# = Netherlands WAP Settings
    *2767*420927# = Czech WAP Settings
    *2767*43927# = Austria WAP Settings
    *2767*39927# = Italy WAP Settings
    *2767*33927# = France WAP Settings
    *2767*351927# = Portugal WAP Settings
    *2767*34927# = Spain WAP Settings
    *2767*46927# = Sweden WAP Settings
    *2767*380927# = Ukraine WAP Settings
    *2767*7927# = Russia WAP Settings
    *2767*30927# = GREECE WAP Settings
    *2767*73738927# = WAP Settings Reset
    *2767*49667# = Germany MMS Settings
    *2767*44667# = UK MMS Settings
    *2767*31667# = Netherlands MMS Settings
    *2767*420667# = Czech MMS Settings
    *2767*43667# = Austria MMS Settings
    *2767*39667# = Italy MMS Settings
    *2767*33667# = France MMS Settings
    *2767*351667# = Portugal MMS Settings
    *2767*34667# = Spain MMS Settings
    *2767*46667# = Sweden MMS Settings
    *2767*380667# = Ukraine MMS Settings
    *2767*7667#. = Russia MMS Settings
    *2767*30667# = GREECE MMS Settings
    *335# = Delete all MMS Messages
    *663867# = Dump Mm file
    #*536961# = WAPSAR enable / HTTP disable
    #*536962# = WAPSAR disable / HTTP enable
    #*536963# = Serial eable / Others disable
    #*53696# = Java Download Mode
    #*5663351# = Wap Model ID [Your Model]
    #*5663352# = Wap Model ID [SEC-SGH***X/1.0]
    #*566335# = Wap Model ID [SEC-SGH***X/1.0]
    *2767*66335# = Check on which model it is
    *2767*7100# = SEC-SGHS100/1.0
    *2767*8200# = SEC-SGHV200/1.0
    *2767*7300# = SEC-SGHS300/1.0
    *2767*7650# = Nokia7650/1.0
    *2767*2877368# = Reset WAP Model ID to standart
    *2767*3855#
    *7465625*638*00000000*00000000#
    #7465625*638*00000000#
    *#7465625# (this is for checking if mobile is locked or not)
    Unlock samsung T319,T509,T819 Free!
    Need no BOX just codes
    procedure :
    1. insert unaccepted sim card to phone
    2. type *2767*3855# (the phone will reboot with full E2P reset)
    3. now *#7465625*638*00000000*00000000#
    4. and #7465625*638*00000000#
    THats it!
    your phone is Unlocked..TESTED BY ME MANY A TIMES
    to b sure u can check it by typing *#7465625* it will show all info about locks
    datdaik95 Đang Ngoại tuyến Thành viên mới
    Nov 2012
    Re: all samsung unlock code
    Phiên bản Avatar 197 auto farm
    Phiên bản Avatar 197 auto farm không bị khóa nick. Bản này mod từ premium 2 của thanbaiks nhưng chạy trên nền Avatar197.
    + Chức năng: Giao diện màu đen, God tiện ích farm, Fix dis 60s , fix lag, Chuyển nv không dis, Mod map và ảnh rất đẹp load mượt, Mod chỉnh ánh sáng m.h (ấn nút gọi), Map chăm farm tiện ích , cuốc đất ,gieohạt,... Đều không bị dis (mình test good rùi nhá)
    - Menu farm:Nông trại, Vật nuôi, Cửa hàng, Rút tiền nhanh, Chuyển nv, Đăng xuất, Thoát
    Phiên bản được tạo bởi Gamethu9x nguồn http://gamethu9x.com
ự, bạn, các, cho, code, download, flash, full, java, không, là, làm, máy, một, mobile, multi, ram, số, từ, tự, đầy, đủ, settings, lock, activate, deactivate, auto, class, reset, gprs, white, restarts, secs, disable, data, enables, check, model, sleep, mode, enable, disables, unlock, version, network, status, subset, trace, samsung, external 4.5 5 12698
