Trang 1 của 4 1 2 3 4 CuốiCuối
Kết quả 1 đến 15 của 48
    longhd108's Avatar
    longhd108 Đang Ngoại tuyến
    Oct 2008
    Hải Dương <--> Hải Phòng
    100 AutoDesk All Product AIO Collection (13/8/10)
    AutoDesk All Product AIO Collection include:
    • AutoCAD 2007 / 2009 (x64) / 2011 (x32-x64)
    • AutoCAD Civil 3D 2010
    • AutoCAD Electrical 2010 (x32) / 2011 (x32-x64)
    • AutoCAD LT 2009 (x32) / 2010 (x32)
    • AutoCAD Map 3D 2011 (x32/x64)
    • AutoCAD Mechanical 2011 (x32-x64)
    • AutoCAD MEP 2011 (x32-x64)
    • AutoCAD Architecture 2008 / 2009 (x32-x64) / 2011 (x32-x64)
    • AutoCAD Raster Design 2009 / 2010
    • Autodesk 3ds Max 2009 / 2011 (x32)
    • Autodesk 3ds Max Design 2010 / 2011 (x32)
    • Autodesk Alias Surface 2011 (x32-x64)
    • Autodesk Inventor Publisher 2011 (x32-x64)
    • Autodesk Inventor Suite 2011 (x32-x64-Server)
    • Autodesk Maya
    • Autodesk Navisworks Simulate (x32-x64)
    • Autodesk Revit Architecture 2009
    • Autodesk Showcase 2011
    AutoCAD
    AutoCAD® software for 2D and 3D CAD design:
    • Explore—Explore design ideas in both 2D and 3D with intuitive CAD tools that help your concepts become real.
    • Document—Drive your projects from concept to completion with powerful documentation tools. Work faster with automation, management, and editing tools that minimize repetitive tasks and speed your time to completion.
    • Communicate—Share critical design data securely, efficiently, and accurately. Experience the benefits of native DWG™ support, one of the world’s most widely used design data formats, allowing you to keep everyone in the loop at all times.
    • Customize—Customizing AutoCAD is easier than you ever thought possible.
    AutoCAD Civil 3D
    AutoCAD® Civil 3D® for civil engineering:
    • Integrated geospatial analysis
    • Surfaces, grading, and dynamic relationships
    • Building Information Modeling (BIM) tools
    • Intelligent pipes layout
    • Integrated hydraulic and hydrological analysis for stormwater management
    • Dynamic quantity takeoff and earthwork calculations
    • Styles, CAD standards, and production drafting
    • Visualization and communication tools
    AutoCAD Electrical
    AutoCAD® Electrical software, the version of AutoCAD® software for electrical controls designers:
    • Standards-based design—Quickly create industry-standard controls designs.
    • Productivity tools—Dramatically increase productivity with electrical-specific commands.
    • Schematic design—Quickly trim wires, copy components, and reuse circuits to easily create schematics.
    • Panel layout—Create panel layout drawings with built-in intelligence.
    • Terminal design—Reduce the complexity of working with terminals.
    • PLC tools—Save time and increase accuracy when working with PLC I/O drawings.
    • Collaboration and data management—Easily share design data with your extended workgroup.
    AutoCAD LT
    AutoCAD LT® professional 2D drafting software:
    • Drawing tools—Use standard shapes such as lines, polygons, arcs, circles, and ellipses to create simple or complex 2D drawings.
    • Modify objects—Modify existing geometry with commands such as stretch, scale, and rotate. Create new objects, copy, offset, and mirror commands.
    • Annotate drawings—Complete your drawings with annotations such as text, dimensions, and hatches.
    • DWG file format—Save and share 2D drawing files with confidence in the integrity and reliability of your data with DWG™ technology from Autodesk.
    • Publish and plot—Create a multisheet DWF™, DWFx, or PDF file, or create a paper drawing set.
    AutoCAD Map 3D
    AutoCAD® Map 3D infrastructure planning software:
    • Geographic coordinate systems—Use real-world coordinate systems to more accurately georeference design data.
    • Direct data access—Directly access spatial data from a variety of data sources, including ESRI® SHP files, Oracle®, and ESRI® ArcSDE® managed databases.
    • Data exchange—Read, write, and convert data in a variety of CAD and GIS formats.
    • CAD editing on geospatial data—Edit spatial data with standard AutoCAD commands.
    • Point clouds—Import and visualize large sets of 3D laser scanning/LIDAR data sets.
    • Analysis tools—Make decisions about your data by creating thematic maps and performing buffer, tracing, and overlay analysis.
    AutoCAD Mechanical
    AutoCAD® Mechanical software, the AutoCAD® software for mechanical design and manufacturing:
    • Mechanical design and drafting productivity tools—Contains a specific tool for almost every aspect of the mechanical engineering and design process.
    • Standards-based drafting and part libraries—Supports international mechanical CAD drafting standards and includes libraries of more than 700,000 standard parts.
    • Machinery generators and calculators—Enables you to instantly create and analyze a wide variety of common components.
    • Documentation and reporting tools—Helps you to easily document, annotate, and report mechanical engineering and design data
    • Collaboration and data management—Enables workgroups to share accurate 2D CAD design information reliably and securely.
    AutoCAD MEP
    AutoCAD® MEP software, the AutoCAD® for mechanical, electrical, and plumbing (MEP) designers and drafters:
    • MEP tool palettes—Work with tools grouped for specific MEP design tasks.
    • MEP systems support—Intuitive tools to design real-world MEP systems.
    • Dynamic input and grips control—Make precise modifications directly in the drawing area.
    • Project Navigator—Manage your project drawings in coordinated views.
    • Catalog-based content—Use extensive collections of MEP-specific parts.
    • AutoCAD® Block and Symbol support—Convert AutoCAD® Block and Symbols to AutoCAD MEP content
    • AutoCAD® and AutoCAD® Architecture support—Use drawings created in AutoCAD® and AutoCAD® Architecture software.
    • Fabrication for MEP contractors—Seamless integration of duct and piping fabrication partner tools.
    Autodesk 3ds Max Products
    Autodesk® 3ds Max® products for 3D modeling, animation, rendering, and compositing—Autodesk® 3ds Max® and Autodesk® 3ds Max® Design:
    • Extensive 3D modeling toolset—More than 100 advanced polygonal modeling and freeform 3D design tools.
    • Shading and texturing—Wide range of texture painting, mapping, and layering options.
    • Animation—Sophisticated toolset for creating characters and high-quality 3D animations.
    • Dynamics, effects, and simulation—Production-proven, high-performance toolsets for creating dynamics and effects.
    • Powerful 3D rendering capabilities
    • Pipeline integration—Import data from many sources and transfer 3ds Max and 3ds Max Design data across file iterations, software applications, users, and locations.
    • Collaborative workflows—Collect and share data in complex scenes, enabling multiple users to collaboratively contribute to the workflow.
    Autodesk Alias Products
    Autodesk® Alias® industrial design software products—Autodesk® Alias® Design, Autodesk® Alias® Surface, and Autodesk® Alias® Automotive software:
    • Concept exploration/integrated sketching—Tools for sketching, illustration, and image editing.
    • Design modeling—Rapidly iterate, refine, and evaluate product design concepts.
    • Productivity tools—Rely on a user-friendly, customizable interface tailored for the needs of industrial designers.
    • Precision surface modeling—Create high-quality surface models, including Class-A surfaces.
    • Reverse engineering—Incorporate changes made to physical models back to digital prototypes.
    • Visualization and communication—Evaluate product design options and communicate design intent.
    • Data integration—Exchange digital design data with industrial design engineering software such as Autodesk® Inventor® 3D mechanical CAD software and other third-party CAD applications.
    AutoCAD® Architecture software, the version of AutoCAD® software for architects:
    • Streamlined user interface—For optimized desktop organization, a larger drawing window, and quicker access to tools and commands.
    • Details—A library of detail components and powerful keynoting tools.
    • Walls, doors, and windows—Draw and document using walls, doors, and windows.
    • Spaces—Automatically tag your drawing, complete with room areas.
    • Sections and elevations—Generate 2D sections and elevations directly from your floor plans.
    • Scheduling—Easily customize the look of schedule styles.
    • Dimensioning—Dimension any wall and all its components.
    • Integrated rendering—Fully integrated design visualization capabilities.
    Autodesk Inventor Products
    Autodesk® Inventor® products for mechanical design:
    • 3D mechanical design
    • AutoCAD® integration and DWG interoperability
    • State-of-the-art visualization
    • Design automation
    • Assembly design
    • Plastic parts design
    • Sheet metal design
    • Design and manufacturing documentation
    • Integrated simulation
    • Routed systems design
    • Tooling and mold design
    Autodesk Maya
    Autodesk® Maya® 3D animation, modeling, visual effects, rendering, and compositing software for film, games, and television:
    • Updated user interface—Enjoy a consistent, enhanced user experience on all platforms.
    • New skinning tools and workflows—Create better skinned characters with more realistic deformations in less time.
    • New non-destructive retargeting workflow—Reuse, correct, and enhance motion-capture and other animation data faster and more easily with a new non-destructive retargeting workflow that uses the Autodesk® HumanIK® middleware libraries.
    • New 3D editorial capabilities—Accelerate pre-visualization and virtual movie-making production.
    • Enhancements to assets and file referencing—More easily segment, reuse, and exchange data with or without file referencing.
    Autodesk Navisworks
    Autodesk® Navisworks® products for construction project management—Autodesk® Navisworks® Simulate, Autodesk® Navisworks® Manage, and Autodesk® Navisworks® Freedom:
    • Model file and data aggregation—Combine project data into a single model for whole-project review.
    • Real-time navigation—Examine the project model from every angle.
    • Review toolkit—Review 3D projects regardless of file size or format.
    • Collaboration toolkit—Facilitate easier project reviews.
    • NWD and 3D DWF publishing—Publish the project to an easily distributed compressed file.
    • 4D scheduling—Link model data to project schedules to plan project activities.
    • Photorealistic visualization—Create realistic images and animations that improve understanding.
    • Clash and interference detection—Find clashes and interferences before building begins.
    Autodesk® Revit® Architecture building design software:
    • Conceptual design tools—Define conceptual forms and geometry as real building components for a smoother transition to design development
    • Bidirectional associativity—Any information that gets changed is changed throughout the model
    • Parametric components—The basis for all building components designed in Autodesk Revit Architecture
    • Revit Building Maker—A more seamless way to turn conceptual forms into functional designs
    • Schedules—A change to a schedule view is automatically reflected in every model view
    • Detailing—An extensive detail library and detailing tools
    • Design visualization—Capture design ideas in a photorealistic state
    Uploaded by astrologic
    softvnn.com
    NOTE :
    Các bạn có thể chọn down từng phần mềm riêng biệt trong link Mediafire trên mà không phải down toàn bộ Collection! Enjoy...!
    Lần sửa cuối bởi playboy6006, ngày 14-08-2010 lúc 04:56 AM.
    hungphieudu_lv Đang Ngoại tuyến Thành viên mới
    Hải Phòng
    Ðề: AutoDesk All Product AIO Collection (13/8/10)
    Trích dẫn Gửi bởi longhd108 Xem bài viết
    hic, có thấy gì đâu mà download, làm ơn xem lại nhé?
    Lần sửa cuối bởi playboy6006, ngày 14-08-2010 lúc 07:31 PM. Lý do: Không quote cả bài dài như vậy!
    longhd108's Avatar
    Oct 2008
    @hungphieudu_lv: ko quote cả bài dài như vậy nhé. Link vẫn bình thường không vấn đề gì hết cả.
  4. The Following 2 Users Say Thank You to longhd108 For This Useful Post:
    thanhcongth Đang Ngoại tuyến Thành viên mới
    ai có bản AutoCAD Mechanical 2006 hoặc 2007 không ? cho xin cái link + key đi.
    Hải Phòng
    :d.sozy,nhầm ...thanks nha!
    awp1323 Đang Ngoại tuyến Thành viên Softvnn
    ngay đây... vậy mà mình cứ đi tìm đâu đâu thanks các bác nhiều lắm lắm
    ngochiep87 Đang Ngoại tuyến Thành viên mới
    Oct 2009
    thanks bác nhiều nha.
    Đặt cục gạch add HF Link !
    chikien276 Đang Ngoại tuyến Thành viên Softvnn
    May 2010
    Công phu quá nhỉ. thank bác, tạm thời chưa down vội, chưa học tới!
    Chữ ký không hợp lệ!
    chẳng thấy mod nào xử lý tên này cả.... chắc đi chơi 2/9 hết cả rồi
    shinmobile Đang Ngoại tuyến Thành viên mới
    Ko có AutoCAD 2007 hoặc 2008 64 bit à bác
    tieulytu Đang Ngoại tuyến Thành viên Softvnn
    load cái 3D Mark ở cái link này về thì ko giải nén đc. nó toàn báo sai pass http://www.mediafire.com/?x3ooah8ii4sq5
    spam:134::134:----------------------------------> kill :178::178:---------------------------->:hopital::hopital:
    không thank kill :134::134:
    thanhcu2008 Đang Ngoại tuyến Thành viên mới
    Re: AutoDesk All Product AIO Collection (13/8/10)
    bộ 3ds max 2011 e download về thì ra 2 cái file .iso. Anh longhd108 chỉ cho e crack chỗ nào với.
    thanks!
    hoanctm8 Đang Ngoại tuyến Thành viên Softvnn
    thai nguyen
    sao mày down cad machenical 2011 về. giản nén đến part 29 thì bị báo sai pass nhỉ????. mặc dù đã đánh pass: softvnn.com. Mod longhd xem lại pass hệ anh em nhé!
    Lần sửa cuối bởi hoanctm8, ngày 29-09-2010 lúc 10:45 AM.
    :134::134::134::134::46::178::178::178::178:
    longhd108's Avatar
    Oct 2008
    Trích dẫn Gửi bởi hoanctm8 Xem bài viết
    Các bạn nếu sai giải nén lỗi thì đọc bài này và tự sửa nhé. Xin cảm ơn.
    http://softvnn.com/forum/announcement.php?f=1040&a=90
    2012 năm của khát vọng, ước mơ được bay lên bầu trời xanh, như con như một con Rồng vươn ra biển lớn.:80:
2009, 2011, bạn, bộ, biệt, các, code, file, include, integrated, không, mềm, pdf, phần, professional, qua, quan, server, từ, toàn, trên, trong, windows, x32, x64, mình, rất, cần, tìm, đang, với, dùm, được, rồi, nữa, nhé, tâm, bận, chủ, thớt, đừng, electrical, autocad, bấy, lâu, 13/8/10, collection, product, lại, link 4.5 5 21705
