    gautruc07129 Đang Ngoại tuyến Thành viên mới
    Mar 2010
    Post Sony Sound Forge Pro 10.0 Full
    Sony Sound Forge Pro software efficiently and reliably provides audio editors and producers complete control over all aspects of audio editing and mastering. Whether in the studio or field, it's the ultimate all-in-one production suite for professional audio recording and mastering, sound design, audio restoration, and Red Book CD creation. New features in Sound Forge Pro 10 include precise event-based editing, integrated disc-at-once CD burning, musical instrument file processing, and pristine audio conversion and time stretching.
    Features:
    - Supports 24-bit and 32-bit/64-bit float 192 kHz files
    - Edit mono, stereo, and multichannel audio files (up to 32 channels)
    - Over 20 real-time DirectX plug-ins
    - Multichannel file editing and processing
    - Real-time editing and processing
    - Automated time-based recording
    - ASIO driver support
    - Customizable keyboard mapping
    - DirectX audio plug-in support
    - VST audio effect support
    - Video and AVI supportUnlimited undo/redo levels
    - Drag-and-drop editing between channels
    - Integrated disc-at-once CD burning
    - Full support for 4GB files
    - And much, much more...
    New features:
    - New customizable window layouts
    - New default fade types
    - New tabbed user interface
    - New performance optimizations
    - New event-based editing
    - New musical instrument file processing
    - New metadata windows
    - Enhanced Broadcast Wave Format (.bwf) support
    - New filters and DirectX plug-ins
    Effects
    - New! Includes Mastering Effects Bundle 2 powered by iZotope
    - New! Zplane élastique Pro timestretch and pitch shift DirectX® plug-in
    - New! Resonant Filter plug-in
    - VST plug-in effect support
    - DirectX® plug-in effects automation
    - DirectX Plug-in Manager
    - Real-time effects previewing
    - Modeless audio Plug-In Chainer
    - Wet/dry mix and crossfade options
    - Acoustic Mirror environment simulator
    - Amplitude Modulation
    - Chorus
    - Distortion
    - Delay/Echo (Simple and Multi-Tap)
    - Graphic Dynamics
    - Multi-Band Dynamics
    - Envelope
    - Flange/Wah-Wah/Phaser
    - Gapper/Snipper
    - Noise Gate
    - Pitch Bend/Shift
    - Reverb
    - Vibrato
    - Wave Hammer Compressor/Volume Maximizer
    What's new in version 10.0
    Event-based editing.
    Disc-at-once CD burning.
    Enhanced timestretch and pitch shifting with the lastique Timestretch plug-in.
    Support for processing musical instrument files (.dls, .sf2, .gig).
    The Global media cache setting on the Editing tab of the Preferences dialog allows you to reserve RAM for media recently read from or written to disk.
    Metadata windows.
    Floating window docks.
    Enhanced Broadcast Wave Format (.bwf) support.
    Enhanced window layout management ? save, recall, and share custom window layouts.
    Tabbed browsing for maximized data windows.
    iZotope MBIT Dither bit-depth conversion and 64-Bit SRC sample rate conversion.
    Resonant Filter plug-in.
    Custom selection grid lines.
    You can now set default fade types for effects on the Editing tab in the Preferences dialog.
    DOWNLOAD:
    UPLOAD by gautruc07129-thongtin47.com
    web detail: [Only registered and activated users can see links. ]
  2. The Following 4 Users Say Thank You to gautruc07129 For This Useful Post:
    AnhPhuc's Avatar
    AnhPhuc Đang Ngoại tuyến Thành viên mới
    Ðề: Sony Sound Forge Pro 10.0 Full
    Sony Sound Forge Pro 10,0 đầy đủ
    Sony Sound Forge Pro phần mềm hiệu quả và đáng tin cậy cung cấp các biên tập viên âm thanh và sản xuất hoàn toàn kiểm soát tất cả các khía cạnh của chỉnh sửa âm thanh và làm chủ. Cho dù trong phòng thu hoặc trường, đó là cuối cùng tất cả-trong-một sản xuất bộ ghi âm thanh chuyên nghiệp và làm chủ, thiết kế âm thanh, phục hồi âm thanh, và tạo ra sách Đỏ đĩa CD. Các tính năng mới trong Sound Forge Pro 10 bao gồm các sự kiện chính xác trên cơ sở chỉnh sửa, tích hợp đĩa-at-ghi lần một đĩa CD, nhạc cụ xử lý tập tin, và chuyển đổi âm thanh nguyên sơ và thời gian kéo dài.
    Các tính năng:
    - Hỗ trợ 24-bit và 32-bit/64-bit float 192 kHz files
    - Hiệu chỉnh đơn sắc, âm thanh nổi, và các tệp âm thanh đa kênh (lên tới 32 kênh)
    - Hơn 20 thời gian thực DirectX plug-in
    - Multichannel tập tin chỉnh sửa và chế biến
    - Real-time chỉnh sửa và chế biến
    - Tự động dựa trên thời gian ghi âm
    - Customizable bàn phím lập bản đồ
    - DirectX audio plug-in hỗ trợ
    - VST hỗ trợ hiệu ứng âm thanh
    - Video và AVI supportUnlimited undo / redo các cấp
    - Kéo và thả hiệu chỉnh giữa các kênh
    - Hỗ trợ đầy đủ các tập tin 4GB
    - Và nhiều, nhiều hơn nữa ...
    Các tính năng mới:
    - New tùy biến cửa sổ bố trí
    - Mặc định mới mờ dần các loại
    - New tab giao diện người dùng
    - Mới hiệu suất tối ưu
    - Sự kiện mới, chỉnh sửa dựa
    - Mới tập nhạc cụ chế biến
    - Siêu dữ liệu cửa sổ mới
    - Enhanced Broadcast Wave Format (bwf). Hỗ trợ
    - New lọc và DirectX plug-in
    Hiệu ứng
    - New! Bao gồm Mastering Effects Bundle 2 bởi iZotope
    - New! Zplane élastique Pro timestretch và chuyển đổi sân DirectX ® plug-in
    - New! Cộng hưởng lọc plug-in
    - VST plug-in hiệu lực hỗ trợ
    - DirectX ® plug-in hiệu ứng tự động hóa
    - Real-time hiệu ứng trước xem
    - Ướt / khô trộn và crossfade Tuỳ chọn
    - Acoustic Mirror môi trường lập giả
    - Chorus
    - Distortion
    - Delay / Echo (đơn giản và đa-Tập)
    - Đồ họa Dynamics
    - Phong bì
    - Flange / Wah-Wah / Phaser
    - Gapper / Snipper
    - Noise Gate
    - Pitch Bend / Shift
    - Reverb
    - Vibrato
    - Wave Hammer Dầu khí / Volume Đa Hòa
    Có gì mới trong phiên bản 10,0
    Sự kiện dựa trên chỉnh sửa.
    Enhanced timestretch sân và chuyển dịch với lastique Timestretch plug-in.
    Hỗ trợ cho chế biến các tập tin nhạc cụ (DLS, SF2,. .. Gig).
    Các phương tiện truyền thông toàn cầu thiết lập bộ nhớ cache trên tab Editing của hộp thoại Tuỳ chọn cho phép bạn dự trữ RAM cho phương tiện truyền thông mới đây đọc từ hoặc ghi vào đĩa.
    Metadata cửa sổ.
    Nổi cửa sổ bến cảng.
    Enhanced Broadcast Wave Format (Bwf). Hỗ trợ.
    Tăng cường quản lý bố trí cửa sổ? tiết kiệm, thu hồi, và chia sẻ bố trí cửa sổ tùy chỉnh.
    Duyệt web theo thẻ cho dữ liệu tối đa cửa sổ.
    iZotope MBit Dither chuyển đổi độ sâu SRC bit và 64-Bit mẫu tỷ lệ chuyển đổi.
    Cộng hưởng lọc plug-in.
    Tuỳ chọn lưới đường.
    Bây giờ bạn có thể thiết lập mặc định cho các hiệu ứng mờ dần các loại trên tab chỉnh sửa trong hộp thoại Preferences.
    DOWNLOAD:
    [url] http://hotfile.com/dl/17829351/46237...10.00.rar.html [/ url]
    Link down có vấn đề rồi. Sao không up lên MediaFile cho dễ down?
    Mà cái này so với SONY Vegas Pro 9.0b Build 772 có gì hơn không nhỉ?....
    Thanks.
    Lần sửa cuối bởi AnhPhuc, ngày 22-03-2010 lúc 08:42 PM.
driver, file, forum, full, html, include, integrated, pro, professional, ram, share, ultimate, video, audio, editing, plug-in, support, effects, sound, processing, window, files, disc-at-once, burning, enhanced, forge, directx, sony, instrument, conversion, real-time, musical, event-based, features, windows, timestretch, 10.0, mastering, pitch, wave, preferences, customizable, media, dialog, plug-ins, channels, multichannel, format, custom, dynamics 4.5 5 5557
