Kết quả 1 đến 15 của 24
Chủ đề: Lỗi màn hình xanh
    chienchuoi's Avatar
    chienchuoi Đang Ngoại tuyến Thành viên năng động
    Lỗi màn hình xanh
    máy mình khi phát wifi cho máy khác bắt, thì bị hiện tượng màn hình xanh. Mình dùng chương trình nó báo lỗi như sau:
    Microsoft (R) Windows Debugger Version 6.9.0003.113 X86
    Copyright (c) Microsoft Corporation. All rights reserved.
    Loading Dump File [C:\Windows\Minidump\Mini090309-01.dmp]
    Mini Kernel Dump File: Only registers and stack trace are available
    Symbol search path is: *** Invalid ***
    * Symbol loading may be unreliable without a symbol search path.           *
    * Use .symfix to have the debugger choose a symbol path.                   *
    * After setting your symbol path, use .reload to refresh symbol locations. *
    Executable search path is:
    * Symbols can not be loaded because symbol path is not initialized. *
    * The Symbol Path can be set by:                                    *
    *   using the _NT_SYMBOL_PATH environment variable.                 *
    *   using the -y <symbol_path> argument when starting the debugger. *
    *   using .sympath and .sympath+                                    *
    Unable to load image \SystemRoot\system32\ntkrnlpa.exe, Win32 error 0n2
    *** WARNING: Unable to verify timestamp for ntkrnlpa.exe
    *** ERROR: Module load completed but symbols could not be loaded for ntkrnlpa.exe
    Windows 7 Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
    Product: WinNt, suite: TerminalServer SingleUserTS
    Kernel base = 0x81801000 PsLoadedModuleList = 0x81918c70
    Debug session time: Thu Sep  3 16:04:14.957 2009 (GMT+7)
    System Uptime: 0 days 0:04:59.739
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    *** WARNING: Unable to verify timestamp for hal.dll
    *** ERROR: Module load completed but symbols could not be loaded for hal.dll
    *                        Bugcheck Analysis                                    *
    Use !analyze -v to get detailed debugging information.
    BugCheck 1000007F, {8, 803d3130, 0, 0}
    *** WARNING: Unable to verify timestamp for ndis.sys
    *** ERROR: Module load completed but symbols could not be loaded for ndis.sys
    *** WARNING: Unable to verify timestamp for nwifi.sys
    *** ERROR: Module load completed but symbols could not be loaded for nwifi.sys
    *** WARNING: Unable to verify timestamp for NETw5v32.sys
    *** ERROR: Module load completed but symbols could not be loaded for NETw5v32.sys
    *** WARNING: Unable to verify timestamp for avfwim.sys
    *** ERROR: Module load completed but symbols could not be loaded for avfwim.sys
    *** WARNING: Unable to verify timestamp for cfosspeed.sys
    *** ERROR: Module load completed but symbols could not be loaded for cfosspeed.sys
    ***** Kernel symbols are WRONG. Please fix symbols to do analysis.
    ***    Your debugger is not using the correct symbols                 ***
    ***    In order for this command to work properly, your symbol path   ***
    ***    must point to .pdb files that have full type information.      ***
    ***    Certain .pdb files (such as the public OS symbols) do not      ***
    ***    contain the required information.  Contact the group that      ***
    ***    provided you with these symbols if you need this command to    ***
    ***    work.                                                          ***
    ***    Type referenced: nt!_KPRCB                                     ***
    ***    work.                                                          ***
    ***    Type referenced: nt!KPRCB                                      ***
    ***    work.                                                          ***
    ***    work.                                                          ***
    ***    work.                                                          ***
    ***    work.                                                          ***
    ***    work.                                                          ***
    ***    work.                                                          ***
    Probably caused by : nwifi.sys ( nwifi+7837 )
    có ai biết nó bị sao k?cách khắc phục nữa.
    thanks các bạn nhiều
    chienchuoi's Avatar
    Ðề: Lỗi màn hình xanh
    Có ai biết k?chắc phải mang đi sửa quá.hic, lại tốn tiền nữa rồi.hờ....
    long<>ham's Avatar
    long<>ham Đang Ngoại tuyến
    Nhấp nháy nè!
    Đang tải [█.................] 1%
    Có thể là lỗi windows hoặc driver/chương trình wifi!
    Chu ki sai quy dinh
  4. The Following User Says Thank You to long<>ham For This Useful Post:
    chienchuoi's Avatar
    mình cài window vista bản untouch, còn driver mình dùng driver trong đĩa kèm theo máy mà.hic
    itdao Đang Ngoại tuyến Thành viên Softvnn
    Trích dẫn Gửi bởi long<>ham Xem bài viết
    Chung chung quá
    Cụ thể là các file DLL bị hư, do đó bị mất thư viện hỗ trợ cho hoạt động của các thiết bị trên máy. Cần tìm các file dll đó đắp vào, hoặc nâng cấp bác Bill lên
    Note; Không nên quá lạm dụng các chương trình hệ thống (quản lý rác, registry, tối ưu hóa.......) vị bọn nó ko có mắt, xóa nhầm hay sửa nhầm là chuyện thường thấy.
    Nghề nào cũng cần có cái Tâm
    -- IT Đạo --
  7. The Following User Says Thank You to itdao For This Useful Post:
    chienchuoi's Avatar
    Trích dẫn Gửi bởi itdao Xem bài viết
    Chung chung quá
    bạn nói rõ hơn đc k?mình update window rồi, vẫn bị thế???hic
    1. Update windows là hoạt động của hệ thống dùng để tải các bản vá của M$ về máy. VD; trong hệ thống có file 1,2,3,4. File 1 bị hư. Nhưng trên website chỉ cung cấp bản update cho file 3 và 4, thì làm sao bạn có thể sửa được.
    2. Phải lấy đĩa vista mới hơn bản hiện tại, đưa vào và chọn UPGRADE
    -- IT Đạo --
    Có thể có một trường hợp nữa là ổ cứng bạn bị bad nặng ở phân vùng cài windows, nên nhưng file thư viện sẽ ko cài đc lên đó.
    -- IT Đạo --
    chienchuoi's Avatar
    mình check bad sector bằng hirent boot oy, nó k bị bad gì cả, vậy là sao ta?
  12. #10
    Hôm trước lang thang trên mạng tình cờ thấy có cái phần mềm
    xem thông tin về lỗi màn hình xanh.
    Bạn thử qua coi xem có giúp ích được gì cho mình không nha!
  13. The Following User Says Thank You to sm2217 For This Useful Post:
  14. #11
    Vậy bạn upgrade win đi, hy vọng là được.
    -- IT Đạo --
  15. #12
    Rongcon.com.vn Đang Ngoại tuyến
    Softvnn.com
    đọc wa mấy cái error kia thì thấy đa fần là các lỗi của file *.sys => đây là lỗi driver. Ở trên kia bạn nói là bạn cài Vista, vậy sao lại có lỗi của win7 nhỉ
  16. The Following User Says Thank You to Rongcon.com.vn For This Useful Post:
  17. #13
    chienchuoi's Avatar
    Trích dẫn Gửi bởi Rongcon.com.vn Xem bài viết
    mình xài vista mà, lỗi của win 7 là sao hả bạn??
  18. #14
    Softvnn.com
    here, mình thấy có đoạn này
  19. #15
    long<>ham's Avatar
    Nhấp nháy nè!
    Bạn down về chương trình này về cho mình:
    http://www.nirsoft.net/utils/bluescreenview.zip
    Sau đó đưa hình lỗi lên đây!
    Chu ki sai quy dinh
2009, báo, bạn, cách, cho, code, file, full, hình, hiện, khác, máy, microsoft, module, nhiều, session, trình, windows, symbols, symbol, path, information, files, .pdb, work, type, command, debugger, loaded, error, load, unable, provided, point, group, referenced, properly, public, required, correct, order, completed, verify, warning, timestamp, contact, nt_kprcb, kernel, loading, variable 4.5 5 3607
