Kết quả 1 đến 15 của 15
    hcm
    hcm Đang Ngoại tuyến Thành viên Softvnn
    Xin phần mềm Hide Folder 2009 + Crack hoặc Key
    zorpia.com/huycoi5
    dongdang Đang Ngoại tuyến Thành viên Softvnn
    Heaven
    Ðề: Xin phần mềm Hide Folder 2009 + Crack hoặc Key
    Hide Folder 2009 v3.10
  3. The Following 3 Users Say Thank You to dongdang For This Useful Post:
    hcm
    Bác nhầm rồi. Đây là bản Hide Folder XP V3.10
    Ko phải bản Hide Folder 2009 em cần tìm.
    Nhưng dù sao cũng cảm ơn bác.
    Trang chủ của nó đây ạ. [Only registered and activated users can see links. ]
    Hide Folders® 2009 - Hide, lock and password protect your private files and folders from other users.
    Hide Folders 2009 is an innovative software application which enables you to password protect all the private information on your hard drive. You can make your files and folders inaccessible, invisible or protect them from modification. The protected folders or files are not accessible by any users - no matter how they are trying to get in - locally or from the net. Effective protection mechanism, intuitive user interface, and set of fine-tuning options will suit the needs of everyone from novice Windows users to computer experts. Since 2001, our Hide Folders software products help our users to hide private files and folders from prying eyes.
    No better way to protect a folder or a file as easy as Hide Folders 2009 does!
    With Hide Folders 2009 you can easily protect any number of folders and files on your computer. You can select any file or folder to protect from the program, drag-and-drop the desired files and folders from Windows Explorer into the Hide Folders 2009 window or protect the file or folder using Windows Explorer context menu.
    Hide Folders 2009 main window
    Lần sửa cuối bởi hcm, ngày 18-02-2009 lúc 01:16 AM.
    zorpia.com/huycoi5
  5. The Following 2 Users Say Thank You to hcm For This Useful Post:
    anhsao2585 Đang Ngoại tuyến Thành viên Softvnn
    Jun 2008
    TheGioiTaiChinh.com
    vẫn chưa có key sao, buồn quá ah
    whoever's Avatar
    whoever Đang Ngoại tuyến Thành viên mới
    Cảm ơn bác dongdang nha!
    duc049 Đang Ngoại tuyến Thành viên mới
    Em cũng đang tìm, các pác giúp em với.
    nghiepduclub's Avatar
    nghiepduclub Đang Ngoại tuyến Thành viên Softvnn
    Bánh Mì Thịt
    cái nè tìm hơi xương!!gần 1 năm rùi mà chưa ra cái key bun ơi là bun
    why not bar Đang Ngoại tuyến Thành viên năng động
    Trích dẫn Gửi bởi hcm [Only registered and activated users can see links. ]
    Các bác cho em Xin phần mềm Hide Folder 2009 có kèm Crack hoặc Key với.
    E đang dùng bản V3.1 cũ quá, không thân thiện như thằng này.
    Cảm ơn các bác nhiều.
    Soft này cũng khá hay...Protect bằng Asprotect nên thử Script mới Patch đỡ cho anh em xài....trên cty toàn xài XP nên ko bít có work trên OS khác hem...pà con test hộ
    http://www.mediafire.com/?zycmjwxwwri
  11. The Following 5 Users Say Thank You to why not bar For This Useful Post:
  12. #9
    bd1808 Đang Ngoại tuyến Thành viên mới
    Trích dẫn Gửi bởi why not bar [Only registered and activated users can see links. ]
    Patch chạy tốt trên windows 7. Cảm ơn bro nhiều nghen :d
  13. The Following User Says Thank You to bd1808 For This Useful Post:
    TLL
  14. #10
    toantit's Avatar
    toantit Đang Ngoại tuyến Thành viên Softvnn
    mới tìm được đây nè bạn:
    mình chưa test vì đang dùng thằng " my lock box "
    cũng của bọn FSPRO, thấy thằng này tuy cũ hơn nhưng trông bắt mắt hơn, dùng thì ngon dễ sử dụng
  15. The Following User Says Thank You to toantit For This Useful Post:
    TLL
  16. #11
    Flying_Dance Đang Ngoại tuyến Thành viên Softvnn
    Oct 2008
    Nếu không seek được Message cho mình, để lại Email mình gửi cho file crack rồi lên trực tiếp trang chủ download về là OK. Mình đang sử dụng đây, có nhiều tính năng nổi bật như: cho phép chế độ read only, khóa, ẩn hoặc cả khóa và ẩn. Nói chung rất good!
  17. The Following 2 Users Say Thank You to Flying_Dance For This Useful Post:
  18. #12
    nhatchidao Đang Ngoại tuyến Thành viên mới
    May 2010
    Thanks bạn Why not bar.
    Tui kiếm cái này cực muốn chít luôn. Phải đăng kí thành viên để Thanks một cái.
  19. #13
    tuanvtpt Đang Ngoại tuyến Thành viên mới
    Re: Ðề: Xin phần mềm Hide Folder 2009 + Crack hoặc Key
    Trích dẫn Gửi bởi toantit [Only registered and activated users can see links. ]
    Phát hiện 1 em NAX TRojan ,là sao vậy toantit
  20. #14
    playboy6006's Avatar
    playboy6006 Đang Ngoại tuyến .: Mỹ Hầu Vương :.
    ♥ Đảo Khỉ ♥
    Re: Xin phần mềm Hide Folder 2009 + Crack hoặc Key
    Xài thằng này vừa miễn phí, lại vừa nhẹ nhàng (chỉ có >190KB):
    * SecureFolder
    http://sourceforge.net/projects/securefolder/
    :33: :33: :33: :33: :33: :33:
  21. #15
    bigthree's Avatar
    bigthree Đang Ngoại tuyến Trial Moderator
    Elf's forest
    DOWNLOAD FULL
    http://www.mediafire.com/?04ltminmh4q
    Crack
    http://www.mediafire.com/?kqmkej5jyxt
2009, bản, các, cho, crack, hiện, không, mềm, nhiều, phần, với, đa, hoặc, bác, hide, folder, như, thiện, quá, thân, cảm, này, thằng, kèm, dùng, đang, v3.1 4.5 5 28051
