Kết quả 1 đến 15 của 18
    than_chet1312's Avatar
    than_chet1312 Đang Ngoại tuyến Củ Chuối Chấm Muối
    Đó đó
    112 Gold Wave Editor Pro 10.2.7 (05/12/08)
    Gold Wave Editor helps you transfer tapes, LPs, live performances, Internet radio, TV, DVD, or any other sound source to your hard drive. The software helps protect your valuable recordings - just set the sound source, the recording quality, and volume, then start recording.
    The Editor allows you to perform various operations with audio data such as displaying a waveform image of an audio file, filtering, applying various audio effects and more. It includes a click and crackle filter for cleaning vinyl records, a noise filter for cassette-tape recordings, and an equalizer to enhance the sound quality of all recordings.
    Key Features:
    • Recording. Record new audio file from a microphone or another sound source..
    • Editing. Open, create and save audio files. Play an audio file or any part of it. Visually edit an audio file (Cut, Copy, Delete, Paste, Paste From File, Mix, Mix From File and Insert or Delete noise or silence in an audio file).
    • Display. Display a waveform window of an audio file and apply zooming.
    • Digital effects. Apply different effects (Amplify, Delay, Equalizer, Fade, Flanger, Invert, Normalize, Reverse, Multi Tap Delay, Silence, Stretch, Vibrato, Echo, Chorus)
    • Audio filters. Apply different filters to the selected part of an audio file (Ban Pass Filter, High Pass Filter, High Shelf Filter, Low Pass Filter, Low Shelf Filter, Notch Filter)
    • Support all major audio formats. Gold Wave Editor supports a wide range of audio formats, such as MPEG (MP3, MP2), WAV, Windows Media Audio, Ogg Vorbis, Audio Tracks and Dialogic VOX. It is easy to convert an audio file from one format to another
    • Ease of use. Gold Wave Editor Pro provides a customizable interface, allowing you to build projects the way you want. It also supports standard Windows keyboard commands and mouse shortcuts
    • Markers. Use markers in your audio file to quickly select between different selections!
    • Selection tool. Select a part of your audio file precisely with the selection tools of Gold Wave Editor
    Build-in Powerful Audio Tools
    • Audio Converter. When you click the Tools > Audio Converter menu item, you can access easy-to-use, yet very powerful, features for converting one file type to another. Supported conversions include the following:
      • * WAV to MP3
      • * MP3 to WAV
      • * WAV/MP3 to WMA
      • * WMA to WAV/MP3
      • * OGG to WAV/MP3
      • * WAV/MP3 to OGG
      • * WAV Compression
      • * MP3 Compression
    • CD Ripper. When you click the Tools > Audio CD Ripper item, you can makes direct digital copies from audio CDs and saves them as MP3, WMA, OGG, and WAV. Supported CDDB and ID3 Tag.
    • CD Burner. When you click the Tools > Audio CD Burner item, you can use the Audio CD Burner to burn custom high-quality CDs from your favorite MP3s and play them back in your car or home stereo or portable CD player! It is fairly simple to use and just a couple of clicks will get you burning. Have more fun with your downloaded MP3 and 'ripped' mp3s or the sound have recorded!
    Homepage-Trang Chủ
    Download-Tải Về
    Serial
    Serial: AMWR-TF477-46YM4-W74MH-6YDQ9
    blink Đang Ngoại tuyến
    Ðề: Gold Wave Editor Pro 10.2.7 (05/12/08)
    Hôm qua tui vừa tải về bản 10.2.2 xong. Ghê quá, than_chet update ghê thật, nhưng mà sao khi mình dow về cài đặt thì nó lại thông báo cài bản 10.2.2 vậy
    Lần sửa cuối bởi blink, ngày 10-12-2008 lúc 07:32 AM.
    klmn1982 Đang Ngoại tuyến Thành viên mới
    troi sao khong down ve duoc vay????
    tuan.cse06's Avatar
    tuan.cse06 Đang Ngoại tuyến
    -= Biệt Thập =-
    Lapland
    Trích dẫn Gửi bởi klmn1982 Xem bài viết
    Tốc độ 128Kbp/s ổn định . Link từ homepage của software mà bạn .Chắc bạn coi lạ coi sao .
    Ta đã trở lại.... Ăn hại gấp đôi.......
  5. The Following User Says Thank You to tuan.cse06 For This Useful Post:
    hattetehat Đang Ngoại tuyến Thành viên mới
    chưa down nhưng cũng cám ơn cái đã!
    jacsonchuong Đang Ngoại tuyến Thành viên mới
    [QUOTE=than_chet1312;800739]
    Key Features:
      • * WAV to MP3
      • * MP3 to WAV
      • * WAV/MP3 to WMA
      • * WMA to WAV/MP3
      • * OGG to WAV/MP3
      • * WAV/MP3 to OGG
      • * WAV Compression
      • * MP3 Compression
    Homepage-Trang Chủ
    => Đồ dởm!
    ==> Đây mới là đồ thiệt Golwave nè http://www.goldwave.com/
    PNU
    PNU Đang Ngoại tuyến Thành viên mới
    đồ này là 10.2.2 à. CÓ bản mới nhất không? Up lên cho anh em cung chiêm ngưỡng nào
    MrDuy Đang Ngoại tuyến Thành viên mới
    Trích dẫn Gửi bởi PNU Xem bài viết
    trên Home mới có bản 10.2.2 mà lấy đâu ra bản 10.2.7 thế. Đây là bản Full Tôi Active share các bạn xài nhé.
    Gold Wave Editor Pro ( New Version ) ! full Active Key
    Home:
    http://www.goldwaveeditor.com/goldwaveeditorpro/index.html
    Download :
    http://www.goldwaveeditor.com/GoldWaveEditorPro.exe
    Download full:
    http://rapidshare.com/files/190936805/Gold.Wave.Editor.Pro.v10.2.2_by_Ta.Duy.rar
    No pass
  10. The Following User Says Thank You to MrDuy For This Useful Post:
    phppro Đang Ngoại tuyến Thành viên Softvnn
    Jul 2007
    Trắng đen thật giả thị phi quá, anh em nào cho một câu chính xác đi, bản của than_chet1312 là ver mấy vậy.
    than_chet1312 có test trước khi up không vậy ?
  12. #10
    ymmy111 Đang Ngoại tuyến Thành viên mới
    Jul 2007
    có link MF không Anh Duy
  13. #11
    Trích dẫn Gửi bởi phppro Xem bài viết
    Hình của thần chết là của 5.xx, còn bản kia chỉ là bản Editor chứ ko phải Pro, treo đầu dê bán thịt chó - lừa Anh Em. Bản của Tôi là Bản Tôi Active là bản Pro, với lại trên Home chỉ có bản 10.2.2 chứ làm gì có bản 10.2.7.,
    Version: 10.2.2
    Released: October 20, 2008
    Platform: Microsoft Windows 2000/XP/Vista
    File size: ~12.0 MB
    Price: $39.95
    order by Ta.Duy
    theo như yêu cầu Tôi sẽ Upleen Mediafire cho các Bạn,
    http://www.mediafire.com/?mikmtnzmdyy
  14. The Following 2 Users Say Thank You to MrDuy For This Useful Post:
  15. #12
    Nam Phong Đang Ngoại tuyến Thành viên Softvnn
    Trích dẫn Gửi bởi MrDuy Xem bài viết
    Version: 10.2.2
    File size: ~12.0 MB
    Price: $39.95
    order by Ta.Duy
    Mấy anh trai này spam vui ghê ! Cái gì là "treo đầu dê bán thịt chó - Lừa Anh em". Chỉ cần thêm link liên kết đến trang chủ để xem bản hiện tại là bản Version bao nhiêu là được , có gì đâu mà "nói lớn tiếng" với nhau....
    Để các bạn khỏi "thảo luận", tôi "thịt" hết software của trang này, tặng các bạn xài chơi cho vui nhé !
    Lên trang chủ ở link trên download bản Trial và sử dụng KEY full cho từng soft bên dưới nhé
    1. Gold Wave Editor Version: 10.2.2
    Code: AMWR-TF477-46YM4-W74MH-6YDQ9
    2. Gold Wave Editor Pro Version: 10.2.2
    Code: GWP-TYBKU-6UY80-UIFK7-ER56J
    3. Gold WMA Workshop Version 2.1
    Activate code: WWP-UIY78-76TYE-56TEV-YUI56
    4. Gold Burn
    Activate code : GB-IOHJ0-TYBFK-WEDXP-BVFHJ
    Mình "thịt" xong xuôi rồi đó, hy vọng các bạn hài lòng !!!
    Lần sửa cuối bởi Nam Phong, ngày 03-02-2009 lúc 08:10 PM.
  16. The Following 6 Users Say Thank You to Nam Phong For This Useful Post:
  17. #13
    boylangtu721 Đang Ngoại tuyến Thành viên mới
    Trích dẫn Gửi bởi than_chet1312 Xem bài viết
    Key Features:
      • * WAV to MP3
      • * MP3 to WAV
      • * WAV/MP3 to WMA
      • * WMA to WAV/MP3
      • * OGG to WAV/MP3
      • * WAV/MP3 to OGG
      • * WAV Compression
      • * MP3 Compression
    Homepage-Trang Chủ
    Download-Tải Về
    Serial
    adasssssssssssssssssssssssssssssssssssssssssssssss ss
  18. #14
    thuandiennang2 Đang Ngoại tuyến Thành viên Softvnn
    trời
    sao nhìu bản thế
    bản nào chạy ổn hả các BÁc
    thank các PRO
  19. #15
    thaivanthien@ Đang Ngoại tuyến Thành viên Softvnn
    các bác làm thế nào chứ e nhìn chóng hết cả mặt,nhìu quá di ko bít nên lấy bản nào đây mới đúng nhất đây!hjx
chủ, code, dvd, file, home, internet, live, menu, mp3, multi, portable, pro, trang, về, windows, audio, filter, editor, wave, gold, sound, tools, click, wav/mp3, pass, effects, apply, part, burner, recording, recordings, source, item, selection, mp3s, display, select, silence, powerful, serial, play, delete, paste, markers, features, shelf, formats, supported, supports, high 4.5 5 11724
