Kết quả 1 đến 5 của 5
    hnn45 Đang Ngoại tuyến Thành viên mới
    Jun 2006
    151 [RS] GetDataBack 3.62 Full (NTFS+FAT)
    Download
    http://rapidshare.com/files/140951114/Get_Data_Back_3.62_Full.zip
    Đây là phần mềm rất mạnh, dùng để khôi phục dữ liệu khi lỡ tay xóa hoặc Format...
    Data Recovery Software for NT file systems - GetDataBack is a highly advanced data recovery software, which will help you to get your data back when your drive's partition table, boot record, Master File Table or root directory is corrupt or lost, when a virus has hit the drive, files were deleted, the drive was formatted or struck by a power failure. GetDataBack comes in two flavours, NTFS and FAT depending on what file system you have.
    GetDataBack will recover your data if the hard drive's partition table, boot record, FAT/MFT or root directory are lost or damaged, data was lost due to a virus attack, the drive was formatted, fdisk has been run, a power failure has caused a system crash, files were lost due to a software failure, files were accidentally deleted...
    GetDataBack can even recover your data when the drive is no longer recognized by Windows. It can likewise be used even if all directory information - not just the root directory- is missing. GetDataBack can even recover your data when the drive is no longer recognized by Windows. It can likewise be used even if all directory information - not just the root directory- is missing.
    The tool works at partition level and will restore files and folders exactly how they used to be. It recovers data from floppy and ZIP disks, drive images and even remote drives connected by a serial cable or TCP/IP. As the name says, it restores files from FAT/ NTFS disks - file system used by Windows NT/2000/XP, yet works on all Windows systems. Make sure you never install the program on the to-be-recovered drive and you will never lose important data.
    Advanced algorithms will make sure that all directories and sub directories are put together as they were, and that long file names are reconstructed correctly. GetDataBack is read-only, meaning the program will never attempt to write to the drive you are about to recover. Please make sure to read the safety instructions...
    The software enables the regular user to conduct his own data recovery by guiding him through three easy to understand steps, thus gives the advanced user the possibility to interfere with the recovery and improve the results, by examining the scan log, the file system details, file and directory information, by selecting the sector range to be scanned, by choosing excessive search for file systems or search for lost files, by calling Runtime's DiskExplorer.
    Recover files over your local network or over a serial cable - This feature enables you to run GetDataBack on one computer ("remote") while accessing the drives of another computer ("host"). Recovering data over a network is useful, especially when you are not able to remove the drive you want to recover from and attach it to another computer.
    GetDataBack recovers from:
    * Hard drives (IDE, SCSI, SATA)
    * USB drives
    * Firewire drives
    * Partitions
    * Dynamic Disks
    * Floppy drives
    * Drive images
    * Zip/Jaz drive
    * Compact Flash Cards
    * Smart Media Cards
    * Secure Digital Cards
    * USB Flash Drive
    * iPod Disks
    Homepage - http://www.runtime.org/gdb.htm
    Lần sửa cuối bởi hnn45, ngày 29-08-2008 lúc 11:53 AM.
  2. The Following 5 Users Say Thank You to hnn45 For This Useful Post:
    phuocdau87 Đang Ngoại tuyến Thành viên Softvnn
    Ai hướng dẫn mình xài cái này vơi,sao mình xài ko được T_T
    hungcuong128 Đang Ngoại tuyến Thành viên Softvnn
    Các bạn download phần mềm này tại đây http://www.4shared.com/file/61021569..._362_Full.html
  5. The Following 3 Users Say Thank You to hungcuong128 For This Useful Post:
    hai_su Đang Ngoại tuyến
    No Where!
    soft này là soft cứu dữ liệu đã bị xóa mất.các bạn chỉ cần setup vào rồi chọn nơi cần cứu (ổ cứng,thư mục....) hoặc kiểu file rồi nhấn recover nó sẽ tìm những file đã xóa ra để bạn tùy chọn để phục hồi.
    Link down mediafire
    GetDataBack for FAT 3.62|2.65MB
    GetDataBack for NTFS 3.62|2.63MB
    Biển học mênh mông, quay đầu lại không thấy bờ đâu!
  7. The Following 6 Users Say Thank You to hai_su For This Useful Post:
    minker Đang Ngoại tuyến Thành viên mới
    Ðề: [RS] GetDataBack 3.62 Full (NTFS+FAT)
    thanks ban nhiu nhiu !
2000, code, dữ, download, flash, full, install, là, liệu, mềm, phần, sata, tay, usb, windows, để, drive, data, getdataback, file, drives, files, recover, directory, lost, disks, root, system, recovery, software, computer, partition, table, failure, cards, make, advanced, systems, information, network, remote, ntfs, recognized, images, recovers, works, floppy, search, missing, hard 4.5 5 24094
